differences in MAF relocate location?!?!?!?! AGAIN!
Old Jul 22, 2010 | 10:17 PM
ericgt79's Avatar
OK now im thinking and i know every company has different reasons to do different things and they test different ways......
dejon runs the maf relocate to the hot side piping before the BOV.
CIA runs the maf relocate to the cold side pipe right below the throttle body.
whats gonna be the difference and which one is better?
Old Jul 22, 2010 | 10:45 PM
Iam Broke's Avatar
Cold side, closer to the correct temperatures the ECU needs for fuel calculations. The IAT1's come from the MAF sensor as well as the flow. The ECU calculates the fueling with these temps at the stock intake. Keeping it on the cold side is most beneficial.
That's what I have ala ZZP cold side CP.
If you put it on the hot side, the ECU will think you are drawing in 150* air instead of say 80* air.
Old Jul 23, 2010 | 05:30 AM
ericgt79's Avatar
understood
Old Jul 23, 2010 | 08:26 AM
Supercharged Guy's Avatar
I have ZZP's maf relocate in my cold side, I dont know if thats screwing it up or what but it's making my car run like **** IMO
Vince said something with my fuel system but 6k miles is hard to believe
Anything is possible though
Old Jul 23, 2010 | 07:35 PM
SSlobalt's Avatar
The MAF was never intended to see boost. That little rubber gasket used to seal it will not hold boost for long, IMO.
Old Jul 23, 2010 | 09:24 PM
Iam Broke's Avatar
~10k miles no leaks at 24 psi+ boost. If the trims shift, I'll make a gasket. When it works, don't fix it.
Old Jul 23, 2010 | 09:32 PM
ei3dag3's Avatar
hope you boost leak checked that.
Old Jul 24, 2010 | 05:20 AM
SSlobalt's Avatar
Man! What a PITA!
Still running OK?
Old Jul 24, 2010 | 08:03 AM
ericgt79's Avatar
you are so right
me and brandon basically were up all night getten my car done last night relocating my maf and **** PITA is right!
Old Jul 24, 2010 | 08:14 AM
mkulrey13's Avatar
We've tried explaining this to you MANY times...
You car runs like **** because you were running STOCK BPV and a BOV on a tune that was for a BOV only. Your fuel problem is NOT hard to believe. Our buddy had a simlar problem, he didnt listen to us then his motor went boom. Go to the dealer and get it checked at asap. They has been a few fuel problems on this site.
Also OP, dejon runs the MAF after the BOV, not before.
Old Jul 24, 2010 | 08:28 AM
ei3dag3's Avatar
yea man if you're gonna run the bov , get a block off plate and stop using the stock bpv.
also you need a maf relocate tune, and like mike said maf relocate needs to be after the bov. generally best before the tb somewhere on the cold side.
why? because anywhere else like the hot side pipe is retarded because its going to see 180+ temps.
Man! What a PITA!
Still running OK?
running like a champ
i might boost leak check it today just to see, but as far as i know its great.
many thanks to you again sir.
Originally Posted by ericgt79
you are so right
hope you got some sleep man, i went to bed at like 2 am, and had work at 6. fml.
i get off at 10 am though.
gonna be going up to scotts house in hutto to do all this.
i'm also gonna do an oil change as well while i'm there.
i'm down to 3%
biniecki
Oct 25, 2015 02:23 PM
Oct 13, 2015 09:32 PM
SSLOW06
Oct 1, 2015 07:21 PM
dieGone
Oct 1, 2015 06:27 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
