Dipstick Issue?
Old Feb 15, 2009 | 01:29 AM
Hill1513's Avatar
Dipstick Issue?
Hey guys. Anyone else's dipstick reading way over? I have changed my oil twice now and the dipstick has read WAY over ever since I've had the car. What gives?
Old Feb 15, 2009 | 09:46 AM
Infidel's Avatar
I would say that that means you have too much oil.
Old Feb 15, 2009 | 09:47 AM
originaladrian's Avatar
usually that means u have to much oil.
ur prob changing ur oil an an incline then putting ur car level.
Last edited by originaladrian; Feb 15, 2009 at 09:47 AM. Reason: Automerged Doublepost
Old Feb 15, 2009 | 10:17 AM
Terminator2's Avatar
How high uo is it reading. The car holds exactly 5 quarts of oil so if you are draining it completely 5 quarts will fill it up perfectly. That all I do and it fills it to the last mark evertime.
Old Feb 15, 2009 | 11:50 AM
DGAF260's Avatar
did you tell the poeple who do youre oil change this and do you know if youre dipstick read high new before the oil changes.
Old Feb 15, 2009 | 11:51 AM
D4u2s0t's Avatar
how much oil do you put? i would say... ding ding ding! there's too much oil!
Old Feb 15, 2009 | 02:33 PM
Hill1513's Avatar
I figured I'd get the "too much oil" response. Haha. I've added five quarts each time I've changed my oil and each time it's read high. I've also had the dealer change it...still read high. I'd say it's reading high by AT LEAST a quart. The car has been at level each and every time I've checked it.
Wrong dipstick maybe?
Old Feb 15, 2009 | 02:38 PM
ls1fbody's Avatar
Haz l33t wheelz.
don't know how its possible, but maybe your dipstick tube is slightly short, or installed slightly too deep into the pan.
Old Feb 15, 2009 | 03:23 PM
Infidel's Avatar
Is it possible that some of the oil isn't draining out? Perhaps some gets trapped somewhere.
Old Feb 15, 2009 | 03:26 PM
USMCFieldMP's Avatar
Rattlesnake Race Shop
When are you checking the oil? That is the important question. Are you checking it on a Cold Engine? Or are you running the engine for a few minutes and then checking it?
I can put 6 qts in mine and not be over the the limit.
Or maybe you are reading the dip stick wrong. Haha.
craigk_c19's Avatar
mine takes 6.5 or is that the difference in the s/c and turbos?
Old Feb 15, 2009 | 03:32 PM
6.5??? THAT sounds high. My S/C takes 6 and its full. I would think 6.5 would be overfilled.
But I would imagine that the SS/TC's take a little bit more oil.
Old Feb 15, 2009 | 03:40 PM
D4u2s0t's Avatar
the ss/tc's actually use alot less oil. my 2.0 is a little over 6.5 quarts to fill. my 2.2 was around 5 or so.
Old Feb 15, 2009 | 03:49 PM
Interesting.
Old Feb 15, 2009 | 06:41 PM
SS_carnatic's Avatar
My car takes only 5 quarts and its right on the perfect level......per the Manual....anybody read those? lol
Old Feb 15, 2009 | 06:44 PM
craigk_c19's Avatar
car didnt come with one or i would read the whole thing!!
Old Feb 15, 2009 | 10:48 PM
Those would probably be on the net eh?
Old Feb 15, 2009 | 11:18 PM
kmandevi's Avatar
Oil and Filter
Are you changing your oil filter at the same time, that can hold some oil in it. Try to measure the amount of oil drained by putting it back in the used containers from the new oil.
Old Feb 15, 2009 | 11:28 PM
Hill1513's Avatar
I'm changing the filter as well and checking the oil after having it sit overnight since I originally thought checking it "warm" was the issue. I don't see how I can be checking it incorrectly. The oil is pretty far up the twisted metal part of the stick.
I also used a 6qt pan to drain the oil into and both times it was the correct among of oil (5qts) that drained out.
Probably gonna have to have the dealer check it out. Looks like the stick or even the tube (as someone mentioned earlier) is not right in one way or another.
DarrenGC
Dec 24, 2021 01:55 PM
Tupp
Sep 30, 2015 08:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
SlowSaturn
Sep 28, 2015 11:03 AM
