Down again
Old Dec 26, 2010 | 05:02 AM
RyRidesMotox's Avatar
Yea but the Lexus IS-F is one hell of a sexy car, I wouldn't mind having one but not for $60,000 or however much they cost. Eric, treadstone is still doing deals on their stage 3 kit. Get it... worth every penny. But you already know that from the ride you took in my balt.
Old Dec 27, 2010 | 09:58 AM
redninja6r's Avatar
The dealer broke mine off. When I took my car to the dealer to be inspected, they came out and said "all 4 rotors need turned, you have a leak at the right rear brake caliper, your end links are loose, and you need a new air filter...will only cost $589" Needless to say, I took it somewhere else. I replaced the rotors with aftermarket drilled slotted, tightened the end caps myself, found there is NO leak in the rear. It took me a couple weeks to get to the airfilter. When I popped the hood, there was the hose sticking up straight in the air. I told the dealer but they of course denied it. So I super glued it on and am finally ordering my K&N Typhoon.
Will never go to that place again, which sucks because it is right next to where I work and real convenient.
On the plus side, I put in a K&N drop in for now, and I am surprised that it really seems a little punchier.
Old Dec 27, 2010 | 02:17 PM
SS-Performance-RS's Avatar
Might do it with tax return. I just dont like the bov sputter. I want mine to fully blow off everytime
Old Dec 27, 2010 | 03:52 PM
If you made it so it would fully blow off at less than 5psi the BOV won't stay closed at higher boost levels... At low boost it will always open a few times because the pressure isn't enough in the CPs to keep the BOV fully open during a low boost situation. I hope that makes sense.
They make the kit without the BOV also so you can keep your stock BPV... Which is a good route also, unless you want to turbo swap. Call up or email treadstone and discuss their options... I think they are ending the discounts on the 1st.
