Dp ?
Old Aug 29, 2010 | 02:53 PM
toeknee(ss)'s Avatar
so i have to cut some wires ok.
Old Aug 29, 2010 | 02:59 PM
northvibe's Avatar
what? no dont cut wires!
Old Aug 29, 2010 | 04:40 PM
Oh $hit 2 late jk ok then no cutting of wires
Old Aug 29, 2010 | 04:48 PM
northvibe's Avatar
no you just need to take off the o2 very carefully. Try not to wind up the wires too much near each end so it doesnt pull the wires out of the o2 or the plug.
Old Aug 29, 2010 | 04:50 PM
feliciano's Avatar
it is catless and in what way is the stock DP much better. and is getting that cel bad news
i have the megan dp it was easy to put in and sounds like i have an exhaust only under load though my cel came on the second day but my car ran fine i got it tuned a week later thats when i felt a difference and they took the 420 code off so no more cel
Old Aug 30, 2010 | 09:36 AM
SSlobalt's Avatar
It's easier to just unplug the O2 sensor.
Old Aug 30, 2010 | 09:49 AM
northvibe's Avatar
I couldnt find the plug...but i found a socket I thought was the plug...then said f it and had rallyracer hold the wires and I turned the o2 out without damage.
Old Aug 30, 2010 | 05:38 PM
Got my DP instaled this morning sounds awesome, lloving it. Sad part is check engine light already turned on coming home from the movies.
Old Aug 30, 2010 | 05:56 PM
Rissa's Avatar
Yeah that'll happen, when you tune it it'll go away, and you'll feel the extra power!
Old Aug 30, 2010 | 08:02 PM
meckel's Avatar
Nobody on this forum worries about screwing up your mixtures when your O2 sensor is reading forced values when tuned, or when reading poor values when the CEL comes on when not tuned?
Old Aug 30, 2010 | 08:14 PM
  #36
good grief, so im screwed either way yes.
Old Aug 30, 2010 | 10:52 PM
  #37
deleted's Avatar
It's just the rear o2. It's not used for mixture calculations. Mainly used to determine if the cat. is functioning and that is why its not really necessary.
Old Aug 31, 2010 | 04:26 PM
  #38
Talking
koo beans
Old Sep 1, 2010 | 02:31 PM
  #39
May I add my car fart a lot more awesome
Old Sep 3, 2010 | 03:33 PM
  #40
meckel's Avatar
So driving around with a cel on when I have my catless do on won't cause any harm or damage at all?
Old Sep 3, 2010 | 03:39 PM
  #41
SSBalt's Avatar
just to the environment
Old Sep 3, 2010 | 03:43 PM
  #42
suprare'09's Avatar
^^^nope did it on my evo8 for like a year (about 12k mi)....NO PERFORMANCE ISSUES...just telling u that ur cat isn't working "efficiently!" if there's no cat, it cant be operating "efficiently"
hey...isn't it tru that with GM stage1 "learn down" is mostly turned off???? if so, shouldn't someone with gms1 feel the added power of a DP a lil more?!?!? just asking...thought i read that in another thread a while back.....
Old Sep 3, 2010 | 03:49 PM
  #43
wantedSS/TC's Avatar
it isn't turned "off" just the DAL's are ramped it in layman's terms to help simplify things.
Old Sep 3, 2010 | 03:58 PM
  #44
ecot3c inside's Avatar
Get a tune, it makes a BIG difference if you are tuned for a dp.
tune for dp= slight raise in low end timing, and some other odds and ends and giggity giggity goo.. big difference, but not a giant difference.
your tuner will probably disable those annoying codes too, but no issues.
lol at 02 sensor unplugging, wonder how that would affect your fuel trims?
Old Sep 3, 2010 | 04:04 PM
  #45
suprare'09's Avatar
so a driver in a gms1 car WOULD or WOULD NOT feel the added power more than a stock tuned car???
would the learn down in a gms1 car still adjust calibrations back to basically negate the added power of the dp??
just trying to be clear on this....my dp is in the mail and i have to consider what to do next! trying to keep gms1 for warranty issues ya know?!
Old Sep 3, 2010 | 04:07 PM
  #46
suprare'09's Avatar
he was talking about for ease of install/removal...and plugging it back in once new dp is installed with O2 sensor in it...just makes it easier than ******* with all of the wires and wrenches while under the car on your back i suppose....
Old Sep 3, 2010 | 04:09 PM
  #47
you will feel added power more in the high-end more or less without a tune, technically you don't need another tune, but should anyways to get those codes blocked that you are predetermined to get. my advise would be to just keep the tune you have, but except the fact you may get a cel, but they also have 02 bung extenders that you can utilize. You will still feel the added power.
Old Sep 3, 2010 | 04:12 PM
  #48
but, then you have to unbolt the o2 while the dp is out and it might be a bitch.. I just unbolted my o2 let it hang, unbolt dp, put on new dp bolt back o2. as for pulling out the wires.. possible, but not very
Old Sep 3, 2010 | 04:14 PM
  #49
suprare'09's Avatar
right on....thanks bro for the help....yeah, i already have a defouler from another car that I will be installing at time of swap!
Old Sep 3, 2010 | 04:21 PM
  #50
suprare'09's Avatar
yeah...i've always dun it your way in the past, but to each their own...i never had a problem tho getting one out without twisting the wires from under the car...
