Drag Strip Questions
Old Apr 11, 2016 | 06:49 PM
20BLACKBIRD02's Avatar
Okay I have been going to the drag strip for awhile, but I am new to FWD at the track, I've had this car for about four years with the mods listed below, I went to the track Sunday, only issues I had were launching but I am on street tires, I trapped pretty high for what I was running, I know the first thing I need to get is drag radials, but if you guys know any other mods that would help at the track that would be great. I ran a 9.04 at 86 MPH. I was spinning through first and a good bit through 2nd. That was the best time I got out of the two runs I did. Launched a little lower RPM on that one and lowered tire pressure to 25 psi.
Old Apr 12, 2016 | 06:10 AM
63 Nova SS's Avatar
If you don't want to go full slick and can change tires at the track, go with the Hoosier drag radials as I think they probably offer the best grip. I have nitto 555r's and they are better than street tires but not as good as the Hoosiers. I drive them back and forth and they have full tread. Launching the cars properly is the key to a low time, and it's not easy. They have plenty of power.
Old Apr 12, 2016 | 01:42 PM
Yeah it is a little rough getting up to launch, I was thinking some drag radials, and low tire pressure, and a low is clutch dump will do, I was getting better at launching and not spinning as much, didnt get to run anymore because they were grudge racing bikes -_-
Old Apr 12, 2016 | 08:19 PM
Herreric's Avatar
Grab some Powell rotated transmission mounts and a HPT tune from a reputable tuner
Old Apr 12, 2016 | 08:58 PM
63 Nova SS's Avatar
What is your setup and mods now? I also agree with the Powell mounts and if you have the money his rear control arm bushings really tightens it up and plants the car better.
Old Apr 13, 2016 | 03:39 PM
As far as suspension its stock, I have torque solutions mounts somewhere, but they vibrated the **** out of my dash, I've heard powells aren't bad at doing that, but I'm sure they all do it a little.
Old Apr 13, 2016 | 03:40 PM
Actually I take that back the guy that had it before me put some type of springs on it, just have no clue what they are, I'll take a picture in a sec to see if you guys know what they are lol
Old Apr 13, 2016 | 06:39 PM
Front and back springs.
Old Apr 14, 2016 | 03:36 PM
umrdyldo's Avatar
IDK what brand those are, but being fully compressed like that is not good for handling. I'm sure your car is low though.
Old Apr 14, 2016 | 03:38 PM
Well it was on the ground when I took em, it's not too low. Back looks almost stock front is pretty low
Old Apr 14, 2016 | 10:06 PM
63 Nova SS's Avatar
What are your engine / transmission mods?
Old Apr 15, 2016 | 03:24 AM
Tranny and clutch are stock, but I have Hahn cold air intake, Injen charge piping, catless downpipe, mpx exhaust, forged bpv, mpx front mount, trifecta 23psi tune with boost cut in first gear, and ngk plugs, I know for sure I need a better clutch, and some drags radials, clutch has 50k on it never been changed, and after some "spirited driving" it will occasionally slip.
Old Apr 15, 2016 | 06:02 AM
63 Nova SS's Avatar
Since you aren't getting as much out of that trifecta tune as an hp tune, and as long as you are fine with your power, you could instead get better "summer" tires and it should hook up that 300-310 whp that trifecta tune is giving you. Get some Powell rotated trans mounts, and I would recommend his rear control arm bushings, along with sticky summer tires and you should be good.
Old Apr 15, 2016 | 01:10 PM
I did hang with a cammed ls1 with 430 gears, I was kinda proud of it, he beat me by a fender, but it was from a roll, I do need a better tune for sure. I'll look into some summer tires, any recommendations?
Old Apr 16, 2016 | 08:22 PM
63 Nova SS's Avatar
Toyo 888's and re71 ( I believe) are the hot ticket for threaded tires. I have Yokohama advan neova ad08r's and they do pretty decent when warm. The really good tech tires are expensive. Federal makes a cheap tire also with a tread pattern like the toyo's but they won't last long from what I've heard ( like under 8,000 miles). A good hp tune with boost ramp really helps. And you also don't have to worry about knock like you do on a trifecta tune, as long as you have a good picky tuner. Knock will kill a non forged piston motor. I had trifecta, I know.
Old Apr 16, 2016 | 10:22 PM
nathan112i's Avatar
look into drag bags and a set of R compounds or slicks if you want to drop some time off the 60 foot. sounds ghetto but some people have had good results with peewee footballs stuffed into the back springs
Old Apr 17, 2016 | 07:01 AM
63 Nova SS's Avatar
I'm gonna try the footballs this year. Would love to do the slicks but at our track that means you run with the bracket cars and that's not much fun. Plus I work late and am not setup to swap tires at the track. If the footballs don't help with my dr's then I will be forced to go with slicks. Trying to stay "street legal" and get the job done.
Old Apr 18, 2016 | 09:40 AM
CudaJoe's Avatar
Id grab some Extreme performance summer tires, and the peewee footballs is an inexpensive solution. Just remember to either deflate them alittle bit or remove them when your done
Looking on Tirerack, I would try Dunlop Direzza ZII Starspecs or Bridgestone Potenza RE-11s/RE-71Rs. If the pricing scares you away there is always Kuhmos new Extreme performance tire. Id even consider trying them. Ecsta V720.
http://www.tirerack.com/tires/tires....omCompare1=yes
Probably better than what ever tire your on now. Consider upping the tire width to 235 or 245 on a 40 series tire.
Here is the Extreme Performance summer tire test chart. Potenza on their list is #1.
Old Apr 19, 2016 | 09:58 PM
63 Nova SS's Avatar
Looks like I have 2nd place tires. Still like them though. I did 235/40-18 on 8" wide rims. They run a little wider compared to my Bridgestone s04's.
Old Apr 20, 2016 | 09:13 AM
CudaJoe's Avatar
Nice, you like them? Have you tried any other tires on that chart as a comparison?
I think for anyone looking for a sticky tire strictly for racing, the only characteristic they should be looking at is dry traction. Personally, Id rather have an overall round about tire which is how this is rated. Im curious what Rank 3, 7, 9, and 10 are. Usually there are top 10 tires. I dont know why they are only showing these? Maybe its the tire size? Some tires not available in that tire size I guess. For traction it looks like
- Re71R
-Re11
-RS3
-the rest are tied which is why I might consider trying the cheaper Kuhmos next time.
Old Apr 20, 2016 | 08:40 PM
63 Nova SS's Avatar
I have not tried anymore on that list. I have some Bridgestone pole position s04 and they don't hold a candle when it comes to dry traction. The advan neova's when warm hook almost as good as my nitto 555r's and surprisingly the tread is wearing very well. The drag radials when hot, do better, but they don't handle worth anything. I wish they would have thrown the proxes 888's in there but I think the comparison is only for what they sell. I've heard the Toyo 888's are the best at dry straight line traction, but they are noisy. Been real happy with my 2nd place tires so far.
Old Apr 20, 2016 | 08:54 PM
blueLNFftw's Avatar
Will a 245/40/18 fit my 8" wheel with a 35mm offset?
Ssc drop springs.
Old Apr 20, 2016 | 09:29 PM
63 Nova SS's Avatar
Originally Posted by blueLNFftw
Will a 245/40/18 fit my 8" wheel with a 35mm offset? Ssc drop springs.
I am getting ready to swap my drag radials off of 7.5 rims and going to 8" because the tread cups on the narrower rims. They are 42 offset and I'm going to 40. I run 245/45/17 drag radials and don't rub so you should be ok with the shorter tire. I did rub 1 time on sport lines, but not on my v3 yyz's. Wish I could find cheap 9" rims as I have that much tread width but I'm not paying that much for rims I hardly use. My m52's with 235-40-18's are 40 offset and don't come close to rubbing. Do you have any 4-5mm spacers laying around just in case?
Old Apr 21, 2016 | 09:07 AM
CudaJoe's Avatar
Ssc drop springs.
im using 235/40-18s on a 40mm offset. Id guess that your tire would be flush with the fender with 245/40/18 and 35mm offset.
Use a wheel tire calculator. stock tire wheel specs:
18"x8" wheel +40 offset
225/40-18 tire size.
Old Apr 21, 2016 | 09:04 PM
I'm using toyo extensa hp I think that's 235/40-18, they don't hook well, I tried 24 psi and they did a little better lol
