Driver Side Door Is Stuck?!
this morning on my way to work i was trying to open the door and it wouldnt open. i even tried rolling the window down and using the handle outside but nothing. So i had to crawl over the center and go out the passenger side. everything seems fine now. BUT do you guys think i should take it to the dealer? Thanks in advance
Was it frozen? I've had the driver door freeze on me once, got in through the passenger side. If both are frozen I imagine I will be crawling through the trunk.
Mine has done it several times. It seems to be a common problem with the Cobalt (among many...) that quite a few members on here have also experienced. There are some other threads regarding this as well.
It's like a ghost problem because when it happens, you don't know when it will happen again.
If your car is still under warranty try taking it in and just ask to have the drivers side door lock replaced.
