Engine Problems? Help!
Old Jun 29, 2010 | 09:34 PM
Josh Leverington's Avatar
I was driving home today and my car sounds completely differently. I have been running a mpx catless dp n catback exhaust for about 2 months so I have grown to know the sound of the car inside n out. The car sounds like a boxer engine now almost like a vr6 vw or a sti, it sounds very deep. It concerned me so much that I went home jacked the car up checked all connections on my exhaust. I had a hunch that it could have been my spark plugs making it sound odd. Then I took my spark plugs out, did a compression test ( 120psi / 150psi across the board) n even put all new spark plugs in...car still runs 15psi of boost n pulls very strong but the exhaust note is polar opposite of what it sounded like yesterday. Any ideas? Should I put my stock dp in n take it to the dealer n have them check it?
Old Jun 29, 2010 | 09:39 PM
JapEatr's Avatar
South Central *********
pull spark plugs, check compression again...the fact that one cyl u mentioned is 120 is not good
chances are #4 piston ring land let go.
Build time my friend, you will soon have a strong engine with performance parts once the disassemble and repair
Old Jun 29, 2010 | 09:48 PM
Forgot to mention. 120psi on the first puff then climbs right to 150 it did that on all 4, all 4 are running a solid 150 psi but the inital crank of the motor brings it to 120
Old Jun 29, 2010 | 09:59 PM
terry11's Avatar
150 is low
Old Jun 30, 2010 | 09:15 AM
SSlobalt's Avatar
I don't think there's anything wrong with it.
Old Jun 30, 2010 | 09:45 AM
Iam Broke's Avatar
Originally Posted by terry11
150 is low
I believe it is perfectly fine for an LNF.
Old Jun 30, 2010 | 02:01 PM
rukkee's Avatar
I would pull the valve cover and take a look ..... people have had broken cam followers and not known it till they pulled the cover.
Old Jun 30, 2010 | 02:29 PM
tom.g's Avatar
Does it always do this or only every once in a while? Another member and myself have had this happen when cruising at highway speeds in 5th gear the car will start to sound just like your describing a Subaru Boxer engine for a few minutes and then everything will return to normal. I'm not sure what this is but it confuses me.
Old Jun 30, 2010 | 02:34 PM
Iam Broke's Avatar
^^^^^^Cam phasers, change the oil sooner.
Old Jun 30, 2010 | 02:41 PM
Idling sounds stock, but throughout all the gears it sounds like a boxer engine now, very choppy sounding
Last oil change was 6,500km ago I do one every 10,000km
Last edited by Josh Leverington; Jun 30, 2010 at 02:41 PM. Reason: Automerged Doublepost
Old Jun 30, 2010 | 02:43 PM
BYT*SS*TURBO's Avatar
My car sounded very "Boxer" sounding when the Front O2 went bad. Cheap thing to try, its $60.
Old Jun 30, 2010 | 02:59 PM
Did it fix it? Do you think it's plauseable cause of my catless dp
Old Jun 30, 2010 | 03:01 PM
Iam Broke's Avatar
I was referring to the sound that comes and goes. If a cam phaser hangs up, it'll sound weird.
The LNF was designed to be a 0w-30 engine but the cam phasers would wierd out when the oil started to break down. A GM engineer posted this on another forum. Oil changes are fairly cheap to try.
I change mine at 50-55% oil life. Usually around 5k miles.
On my car that was the fix. If you have the ability to look at the trims it's easy to tell when it's bad.
turbochargedss2012
Sep 20, 2023 12:17 PM
brandon04
Oct 21, 2015 07:04 AM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
DocSvensk
Sep 27, 2015 02:24 PM
