Engine question
Engine question
It only happens when it's cold and I assume its normal
The temps in ny have been ass backwards going up and down like crazy
when i start my car on a cold start it'll sputter type like drop down in RPMS then go back up to normal high idle, is this normal because of the weather change?
Well its due to the cold. Fuel and the maf . Maf is based on a heated wire that gives correct fueling when air is passed through it. So if its colder or warmer is wussrs dictates the fueling. So its prob just from the cold maf or cold fuel .. or even drastic changes in weather.
I've noticed my car does it right as the starter is retracting in cold weather. I got the noise, pretty sure it was just my flywheel being ground down a little bit
. Today it was in the 40's and started with no issue whatsoever.
patooyee
Oct 1, 2015 01:07 PM
