Engine question
Old Jan 6, 2012 | 10:15 AM
steven2008ss's Avatar
Engine question
It only happens when it's cold and I assume its normal
The temps in ny have been ass backwards going up and down like crazy
when i start my car on a cold start it'll sputter type like drop down in RPMS then go back up to normal high idle, is this normal because of the weather change?
Old Jan 6, 2012 | 05:14 PM
09TcSedan's Avatar
sounds like the exact problem im running into upon cold starts. dose it give off a weird noise once you see the rpms drop?
Old Jan 6, 2012 | 05:18 PM
Chevycobaltss3's Avatar
Well its due to the cold. Fuel and the maf . Maf is based on a heated wire that gives correct fueling when air is passed through it. So if its colder or warmer is wussrs dictates the fueling. So its prob just from the cold maf or cold fuel .. or even drastic changes in weather.
Old Jan 6, 2012 | 06:08 PM
Thanks James and to the other guy no, no rattling
Old Jan 6, 2012 | 06:41 PM
Ch1ck3n's Avatar
I've noticed my car does it right as the starter is retracting in cold weather. I got the noise, pretty sure it was just my flywheel being ground down a little bit . Today it was in the 40's and started with no issue whatsoever.
Old Jan 6, 2012 | 07:11 PM
Before cranking let the car be in on position and see if it helps.
brandon04
Oct 21, 2015 07:04 AM
HEATON
Oct 16, 2015 07:21 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
DocSvensk
Sep 27, 2015 02:24 PM
