A/F Setup
A/F Setup
So I plan on getting Interceptors before I start modding my car more. Mostly for safety sake and because I like knowing what's going on with my car. I know interceptors have inputs for a/f , egt, ect. My question is I've read that the LNF already uses a wide band. Is there any way to get the interceptors to read a/f with the stock O2. If not is the only way aeroforces kit or will an AEM wide band kit work?
Also I wouldn't mind seeing pictures of some set-ups. Most people seem to run pillar pod . Though I am leaning toward bezel or column mount.
But it will read a digital display like the other parameters I believe.
Im not so sure that I need super high speed real time just the ability to see it and if it gets unsafe near a certain range.
Does it read A/F off the OBD port or a connection to the sensor? For those of you with it and stock O2s.
ThoR294
Oct 4, 2015 08:44 PM
