A/F Setup
Old Jun 24, 2011 | 06:38 PM
DirtyBalt09's Avatar
A/F Setup
So I plan on getting Interceptors before I start modding my car more. Mostly for safety sake and because I like knowing what's going on with my car. I know interceptors have inputs for a/f , egt, ect. My question is I've read that the LNF already uses a wide band. Is there any way to get the interceptors to read a/f with the stock O2. If not is the only way aeroforces kit or will an AEM wide band kit work?
Also I wouldn't mind seeing pictures of some set-ups. Most people seem to run pillar pod . Though I am leaning toward bezel or column mount.
Old Jun 24, 2011 | 06:48 PM
peachpuff's Avatar
As long as you get the CN series gauges they'll read the afr no problem.
Old Jun 24, 2011 | 11:17 PM
TcKid631's Avatar
my interceptor reads afr's of the cars o2 sensor but i feel like it lags a little with the readings it gives me.
Old Jun 24, 2011 | 11:20 PM
smthomas556's Avatar
Do they read EGT's?
Old Jun 25, 2011 | 01:25 AM
TcKid631's Avatar
Originally Posted by smthomas556
Do they read EGT's?
Nope not unless you buy a sensor and wire it up to be a analog reading
Old Jun 25, 2011 | 02:16 AM
But it will read a digital display like the other parameters I believe.
Im not so sure that I need super high speed real time just the ability to see it and if it gets unsafe near a certain range.
Does it read A/F off the OBD port or a connection to the sensor? For those of you with it and stock O2s.
Old Jun 25, 2011 | 10:40 AM
peachpuff's Avatar
It reads the afr from the obd port. An egt gauge won't do you much good, the ecm dumps extra fuel if the cat temps get too hot anyway.
RaginChopsuey
Oct 27, 2015 01:27 PM
patooyee
Oct 15, 2015 05:11 PM
ThoR294
Oct 4, 2015 08:44 PM
cw383
Sep 30, 2015 12:41 AM
anotherslowlnf
Sep 29, 2015 03:52 PM
