forge bpv sound.
Old Jan 14, 2013 | 10:22 PM
joezombies's Avatar
forge bpv sound.
Ok so a while back k I took the plunge and bought the forge bpv. The old one. Not the new atmospheric one. Ok so I I have a true cold air intake that ends at the filter end with 3". It makes my turbo whistle loud as hell. And my stock bpv was loud as hell too. Sounded almost like a bov but not quite. So I put in this forge bpv and now you can barely even hear the thing when I shift. Has anyone else experienced this same phenomenon?
Old Jan 14, 2013 | 10:34 PM
BlackARCA06's Avatar
My Forge BPV I had was quiet...made a chirp noise and that was it.
Old Jan 14, 2013 | 10:39 PM
Sox-Fan's Avatar
Got Brakes?
Mine was quiet for a long time. It eventually after a few months wore a bit and started to get noisier.
Old Jan 14, 2013 | 10:42 PM
joezombies's Avatar
Very disappointing... so many people said they were way louder than the stock bpv even seen comparison vids where they seemed louder. But then again as I stated above my stock rubber diaphragm bpv was as loud as a bov almost. I used to catch people off guard walking and scare them. You think the stiffer spring would be louder maybe? I hope it gets louder then. I only had it in a short while before parking it to fix rear brakes and been parked ever since. Stupid defective rear brakes!!!
Old Jan 14, 2013 | 10:44 PM
user 72239's Avatar
All the forge BPV is designed to do is replace the stock BPV which is cheaply made. thinking the sound would be any louder was something it was never designed to do. you want a BOV sound, by the Forge VTA BPV or a real BOV
Sox-Fan's Avatar
Got Brakes?
No, it wouldn't be louder, it would just make your car run shitty.
It wasn't intended to be louder, so it's not. It was intended to be more durable than the rubber diaphragm stock BPV, which it probably is, if you service it from time to time.
Old Jan 14, 2013 | 10:51 PM
joezombies's Avatar
Lol well my stock one was way louder. I didn't just buy it to be louder, however most people reported they were so I figured that would be an extra perk. And I have already ran a bov on it. Honestly I loved the sound even if most people call it rice, but it was a pita due to it ******* with my a/f ratios and putting the car in limp mode all the time. I've wanted to get a tune for a while but everything else has gotten in the way and definitely not going to get a tune just for a bov lol that would be dumb.
Old Jan 14, 2013 | 11:05 PM
TheTruth7's Avatar
Mine sounds absolutely amazing. No problems.
Old Jan 14, 2013 | 11:09 PM
user 72239's Avatar
Pretty easy fix to run a BOV. Lower charge pipe with MAF relocate. block off stock BPV and get tuned. done. a bunch of people I know have done this and had no problems. the key thing is you need a tune. some people run fine without a tune and then it screws up.
Old Jan 14, 2013 | 11:16 PM
joezombies's Avatar
Lol people on here talk about tunes like its $1 a run. I live in oklahoma and cant seem to find crap for dyno tuners andthe places I have been able to find onine its like $300 an hour and I don't have that kind of dough lying around all the time. One place I called that was cheaper only does imports and when I told them what it was they were like nope and hung up.
Old Jan 15, 2013 | 02:35 AM
Nfamous60's Avatar
such diccs you should throw pain on the cars in the parking lot.
Old Jan 15, 2013 | 08:18 AM
user 72239's Avatar
Right, I never said it was cheap lol. I had the same problem so i bought HP Tuners Pro off here for 250 bucks and when it was all said and done the total was around 700ish for my tune lol. Im just saying to make it run right you need a tune.
Old Jan 15, 2013 | 12:06 PM
joezombies's Avatar
Yeah I know I've been wanting a tune for a while just have had other things come up and other priorities like buying a house.
Old Jan 15, 2013 | 01:42 PM
Cobe's Avatar
I would only get one of these to put it in the zfr and I would only install that on the turbo before I installed it.. lol
Old Jan 15, 2013 | 08:14 PM
joezombies's Avatar
id love to be able to afford one. probably could tax time, but im a working joe without mommy and daddy to back me up so that will probably pay bills.... that is if i get anything back since im in a higher tax bracket and the present administration either wants you rich or dirt poor. I should be ashamed of myself for working so hard and putting in all the extra hours to provide for myself instead of letting uncle sam pay my way through life lol.
Old Jan 22, 2013 | 01:08 PM
Silverbullet33's Avatar
does the forge fit on a ZFR? better then stock ceramic when you use the green spring + forge bpv?
Old Jan 24, 2013 | 07:15 AM
Aleksey's Avatar
Personal experience, Forge BPV won't add any additional sound. Though, with K&N short ram you can definitely hear the difference between stock and Forge. Forge one prolongs the sound but other than that it's not any different and isn't made for sound but more for a good quality aluminum replacement item for stock plastic one.
Old Jan 24, 2013 | 08:26 AM
user 72239's Avatar
yes it will fit in the ZFR
Old Jan 25, 2013 | 12:31 PM
^ thank you, i figured i should upgrade to it if itll fit, just incase
turbochargedss2012
Sep 20, 2023 12:17 PM
Jan 12, 2016 12:01 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
HEATON
Oct 16, 2015 07:21 PM
Sep 27, 2015 08:53 PM
