Front Hub 2009 SS
Old Jun 13, 2016 | 03:37 AM
stevehendo34's Avatar
Front Hub 2009 SS
Noisy Bearing.
Got break caliper and brake rotor off.
Removed three hub bolts and axle nut.
Hammered on hub a couple hours without luck.
??Any tips tricks??
My car is starting to fall apart.
Old Jun 13, 2016 | 07:59 AM
Are the axle splines stuck in the hub or no? I dealt with hubs becoming somehow permanently fused to the knuckles. Ended up just replacing everything.
Old Jun 13, 2016 | 09:29 AM
yellowsupercharged06's Avatar
see if the axle splines are loose ... if they are go rent a slide hammer from autozone.
this is what i had to do to replace mine. The one i rented took about 3 good slides and it came right off.
Just a tip: the tool i rented had 3 mounting holes but since we have a not so common bolt pattern it didnt fit so i had to do a little grinding on the tools holes so it would fit over 3 lug studs. it was so little they didnt notice it when i returned the tool.
Old Jun 14, 2016 | 12:47 AM
tomj77's Avatar
Mine came out a little hard, basically fell apart, was rusted bad. When u install new one, use antiseize on the axle splines and any other place u can, it makes for
Much easier removal next time
Old Jun 14, 2016 | 02:57 PM
ionRL_585's Avatar
Originally Posted by stevehendo34
Noisy Bearing.
??Any tips tricks??
P.B. blast the **** out of it where it connects to knuckle then thread one of the bolts back into one of the lower holes slightly, then use the socket that you used to take off the bolt and put it on the bolt then add a couple extensions to act as a press.
Have someone turn the steering wheel to have the extensions press towards the frame [Use a rag or 2 to prevent dents!] and once you have enough pressure start hammering on the side the make shift press is on and it will start coming out. Do the same to the other side and boom. The ABS ring will be more than likely stuck but a flathead wrapped in a rag solved that.
Anti seize is your best friend. Lube the hell out of the new assembly before installing.
How to requests and questions
Jun 23, 2016 09:49 AM
GreenStang
Jun 16, 2016 12:54 PM
Shanman
Jun 12, 2016 09:46 AM
xRedrumisBack
Jun 10, 2016 12:18 AM
GreenStang
How to Guide
Jun 6, 2016 11:34 AM
