Front turn signal issue
Old Dec 22, 2015 | 06:02 PM
Northindy's Avatar
Anyone ever have to replace the front turn signal socket? I can't find anywhere that sells the part except for GM, and GM only sells it with the lens as a complete assemble for about $225. Kind of steep for what should be a $10 fix.
So far I have not had any luck at a junk yard either.
I had the moisture in the headlamp issue and so I caulked around the seal (between the lens and back half of the assemble). When I put the bulb back in, it would not work. A new bulb did not solve the problem. It does work intermittently, so there is obviously a short somewhere. I tried cleaning the contacts, and of course broke a few of the small plastic tabs.
The turn signal socket has 5 wires. Most sockets on line show only 3 or 4 wires (not 5).
I searched on line and various forums. A few people had the problem, but no one posted a solution.
Thanks!
Old Dec 22, 2015 | 06:56 PM
Bass_Waves's Avatar
Sounds like you need headlight bulbs harness
I have 2 brand new for 35$ shipped
Old Dec 22, 2015 | 08:45 PM
ATOMbomb's Avatar
Did you change the blinker fluid? Jk sorry had to say that. Yea you can only really buy the full headlight harness not just the socket unfortunately. At least that's all I've heard.
Old Dec 22, 2015 | 10:11 PM
rrob5382's Avatar
Isn't it a 3157 bulb? You could just buy the socket and wire it in. Just Google 3157 socket
Old Dec 23, 2015 | 09:37 AM
Northindy's Avatar
Base_waves - I just sent you a PM for more details.
rrob - the bulb is 3457 (amber), and all the sockets shown on-line for 3157, etc., all have 3 wires. I need one with 5 wires.
Thanks for the info.
06SS Browns Fan
Aug 7, 2016 07:34 PM
budah93
Dec 26, 2015 08:34 PM
DVUSz06
Dec 26, 2015 03:35 AM
Dustnyou
Dec 20, 2015 10:31 PM
DVUSz06
Dec 18, 2015 03:36 PM
