Gear whine?
Old Nov 5, 2008 | 10:48 PM
Force's Avatar
Gear whine?
I've been hearing this faint whining noise while coasting in gear, particularly in 2nd and 3rd... I'll be on the throttle and let off around 3k rpm, then it starts. It disappears when I get back into the throttle.
I'm assuming this is normal enough, but I figured I'd double check here. Any insight?
Next, my sunroof gives off a nasty rattle when it's open... Another common Cobalt problem I'm guessing?
Thanks in advance.
Old Nov 5, 2008 | 11:04 PM
MARIN007's Avatar
Whine=Normal
Sunroof=wtf. Send to dealer for fixage.
Old Nov 6, 2008 | 01:14 AM
jarhead's Avatar
Thanks in advance.
Mine did that also when it was about two months old was just a loose bolt on the passenger side of the sunroof was a star pattern bolt tightened it up noise gone.
Old Nov 6, 2008 | 01:32 PM
madlion's Avatar
i have whine when cold. most of it goes away by the time it is warm. also a little clutch chatter... nothing too major but for the most part all of the posts i have read call this normal
Old Nov 6, 2008 | 01:38 PM
06superchargedbalt's Avatar
normal! i have it as well.
Old Nov 6, 2008 | 06:35 PM
Koz!'s Avatar
I haven't noticed any gear whine at all.
Old Nov 7, 2008 | 02:11 PM
lecznar1's Avatar
mine whines and there is also a little bit of clunk on the clutch all normal until things heat up then it's smoother than a baby's behind!!
Old Nov 7, 2008 | 02:52 PM
Rownan's Avatar
I love all the little sounds this car makes.. I turn down the stereo all the time just to listen to the whirrring and pshhhhing and clunking.
Old Nov 7, 2008 | 03:19 PM
lecznar1's Avatar
haha me 2 if i ever get mad just crank that **** up and listen to the pioneer pound!!
Old Nov 9, 2008 | 12:47 PM
Koz!'s Avatar
Well I retract my initial post...I've started to notice a tiny bit of whine, and I agree, it doesn't seem like a problem at all.
However, just yesterday something started to happen which really does have me concerned. When the car is cold and I hit a dip in the road, a sound comes from pretty much right under the shifter (perhaps a bit more towards the front of the car). First I thought I had scraped my chinspoiler or something, even though I had driven over that particular bump for years with no problems...but then it did it again on a much smaller bump, so I knew I wasn't scraping. Peeking under the car later confirmed that I didn't scrape. It's happened a couple times since then, but most of the time I had the radio on so I didn't hear it very clearly. One time though, I did catch it with the radio off, and it almost sounded like the transmission was grinding! The sound came from below the shifter, maybe a little bit closer to the front of the car (not exactly where the transmission is though...), and sounded pretty similar to how it sounds if you grind gears. The thing is, I wasn't shifting when the sound happened...I was completely in gear and just driving down the road.
I'm trying to pinpoint the noise a little better, and then I'll see about taking it in to have it looked at. I want to try to hear it more clearly a few more times. Also, it only seems to happen when the car isn't warmed up all the way.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
biniecki
Oct 25, 2015 02:23 PM
DocSvensk
Sep 27, 2015 02:24 PM
ashalle2
Sep 16, 2015 10:36 PM
