Gm stage 1
Old Jun 23, 2010 | 07:01 PM
RJT's Avatar
RJT
Question Gm stage 1
Has anyone experienced the following......
95 degrees outside today.....my balt was like in limp mode.....would not go over 5 er 6 lbs of boost....run like crap......anyone ?
Old Jun 23, 2010 | 07:18 PM
Cpanthers85's Avatar
It's 95* out here for 1/2 the year and I have GMS1...never had problems like that. Still boost around 20-22psi. I have noticed the AC draws a TON of power, especially when starting out or downshifting it's not as responsive, but that's about it...
Might be a problem with the GMS1...somtimes the Map Sensors come off or aren't installed properly, which will cause the car to go into "limp" mode.
Old Jun 23, 2010 | 07:24 PM
DoMiStIc_RuSh_06's Avatar
There are a bunch of us that's having this issue.
Old Jun 23, 2010 | 07:57 PM
RJT's Avatar
RJT
Yup , as I research it I see that , that sucks ! mapp sensors need soldering,sum times replace maf sensor.....**** that means return to stock too !
Old Jun 23, 2010 | 08:17 PM
EcotecAddict's Avatar
I totally agree, driving with the AC on sucks! RPMs drop way to fast and the engine lugs a bit in higher gears, especially uphill. But I would check your MAP sensors, I know the one on the lower charge pipe (cold side) has a tendency to come loose or not have a good seal with the pipe.
DarrenGC
Dec 24, 2021 01:55 PM
HEATON
Oct 16, 2015 07:21 PM
nathan112i
Sep 30, 2015 07:12 PM
grampss
Sep 27, 2015 08:51 PM
