GMPP Clutch
Old Mar 27, 2014 | 07:22 PM
  #51
63 Nova SS's Avatar
Originally Posted by TCBalt09
Where did you guys get your clutches and flywheel from. Dealer wants $1285 labor only to do the clutch if I supply all parts!
My local dealer quoted me $685 labor, what does your dealer charge per hr of labor $200? That's outrageous.
Old Mar 27, 2014 | 07:56 PM
  #52
bspeed's Avatar
Originally Posted by sl0wlsj
Buy the full kit from CED. Includes everything you need.
Cobalt - HHR LNF Clutch Kit 24239996K
why is this so cheap? how many ftlbs of torque is this clutch rated to? if this is the exact one my buddy had he made 412whp382ftlbs, seemed good for him
Old Mar 27, 2014 | 08:05 PM
  #53
bspeed's Avatar
Originally Posted by Wert842
Wow... I dropped my car off at my buddy's garage at 7:30 and at like 10 they called saying it was done. Took 2 guys and cost $300...
im going to your buddies garage haha
Old Mar 27, 2014 | 10:13 PM
  #54
I wouldn't pay anymore than $500 labor.
Old Mar 28, 2014 | 04:20 AM
  #55
tuned08ss's Avatar
I would like to find a shop that charges $500 or less in NJ.
Old Mar 28, 2014 | 04:59 AM
  #56
TCBalt09's Avatar
This. $500 around here will get it done in someone's backyard on a weekend with only floor jacks.
Old Mar 28, 2014 | 02:31 PM
  #57
GTOworshiper9's Avatar
Lol so many cheap asses in here. Book time is 8.1 hours for a clutch and 6.1 for warranty (which obviously doesn't apply here since it's customer pay) and that's what you're going to be billed at regardless of how long it actually takes
Old Mar 28, 2014 | 03:34 PM
  #58
TCBalt09's Avatar
Even at 8 hours that's should be around $800 based on the common $90 and hour rate. My dealers wants 1285
Old Mar 28, 2014 | 03:42 PM
  #59
TCBalt09's Avatar
So just to recap, buy the GMPP kit from Ced, pick up a new flywheel, new flywheel bolts, clutch pipe , and good?
Old Mar 28, 2014 | 04:22 PM
  #60
Gelladuga69's Avatar
Damn, you guys get ripped. I had 2 buddies pay $400 each for a clutch job at a indy shop after they saw me struggle in my garage.
Old Mar 28, 2014 | 04:34 PM
  #61
T-Man's Avatar
Only difference between the GMPP and LNF clutch is the disc itself. Both are extremely capable of holding big power. FWs are almost identical too. Smaller dowels on LNF FW I believe. LuK manufactures an OEM LNF replacement FW that can be had for $110-120.
My 40k stocker is holding 378ft/lbs. However, I just picked up another stocker to replace it as my TOB/slave is dying and if I'm going in there, I might as well replace it all.
Fwiw, my previous RY sedan held well over 400ft/lbs running ethanol without a hiccup. The clutches are VERY capable
Old Mar 28, 2014 | 07:47 PM
  #62
TCBalt09's Avatar
Found the kit for cheaper at summit. CED wants $302 Shipped for the clutch. Summit wants $270 with free shipping
http://m.summitracing.com/parts/nal-19212712
Old Mar 28, 2014 | 09:09 PM
  #63
tuned08ss's Avatar
Yes or get your stock flywheel resurfaced. I would just buy new though ftom zzp
Old Mar 28, 2014 | 09:11 PM
  #64
TCBalt09's Avatar
Do I need pressure plate bolts too?
Old Mar 28, 2014 | 09:26 PM
  #65
buildmeanempire's Avatar
I think that they are tty so yes, I would.
They are like $2.30 apeice on gmpartsdirect
Old Mar 28, 2014 | 09:47 PM
  #66
southal cobalt's Avatar
im fairly sure that the pressure plate bolts are not tty, but they do come with the clutch kit. at least they came with my gmpp kit
Old Mar 29, 2014 | 12:23 AM
  #67
TCBalt09's Avatar
From Ced?
Old Mar 29, 2014 | 12:36 AM
  #68
seeyaass's Avatar
I'm in pa lol it's Easy you can do it yourself.
Old Mar 29, 2014 | 12:38 AM
  #69
seeyaass's Avatar
Lol hell yea I'd do it for 500 bucks in a day .
Old Mar 29, 2014 | 03:57 PM
  #70
cfsnipers's Avatar
Anyone ever mess around with a GMPP pressure plate and a different disk? or any kind of mismatched setup like that?
Old Mar 29, 2014 | 11:05 PM
  #71
chris88z24's Avatar
Does anyone's grind when shifting to reverse?
Old Mar 30, 2014 | 03:03 AM
  #72
Then they obviously charge more then the "normal" rate. Around my area a shop would never be able to survive at $90 an hour
Old Mar 30, 2014 | 03:23 AM
  #73
TCBalt09's Avatar
As in too high right?
Old Mar 30, 2014 | 06:43 AM
  #74
red08ss's Avatar
i,m confused i thought the kit was 19212712 ? or are the parts the same ? or is the above the stock kit ?
Old Mar 30, 2014 | 07:30 AM
  #75
The HHR clutch kit is the stock clutch. The LSJ clutch upgrade is the GMPP (19212712)
