Great turbo upgrade for lnf 2.0 engine!!
BTW, I got the stage 2 tranny mounts and the Ingalls from OTTP, the engine mount from TTR, the level 5 axles from driveshaftshop (to come soon), the Clutchmaster stage 4 with flywheel and I'm on new toyo proxes. I hope it helps for the traction. If there is anything else to improve traction, please let me know
You really only need the stage 2 trans mounts and I don't believe the TTR engine mount worked with the trans mounts (could be wrong) you really didn't need the Ingalls with the other mounts.
2900lb car? The sticker on my door says 3900lb
yep byt.....100% on the hpt program. but im pretty much at the max of what i can do with it. im sure we could squeeze a bit more of it but you will just have to wait and see what comes for the future. i dont want anymore hp without a built motor... the lnf in my car is bone stock.
THE ONLY THING I SEE WORTH IT IN THERE IS THE POWELL STAGE 2 MOUNTS.....TTR engine mount is junk....ask me how i know...ingalls will not work on the lnf cars. i bet those axles were a pretty penny. theres better tires then the proxes too. are you trying to road coarse this car or drag race it? if you plan on mostly road coarsing it the stock axles should be fine. thats what i run.
I'm, receiving the Autowerks pte 55/57 kit in a couple of weeks, which I know is the one you have. What else should I do? What do you recommend? Is that intake manifold that I saw on your pic worth it?
i recommend with this kit you have an intercooler and exhaust if you dont hve one already.
Last edited by whyyoumadson?; Dec 5, 2010 at 09:46 AM. Reason: Automerged Doublepost
i recommend with this kit you have an intercooler and exhaust if you dont hve one already.[/QUOTE]
So far, to be installed with the kit, I've ordered the Hahn intercooler and the Clutchmaster stage 4 with the flywheel. BackYardTurbo will do the install.
Turbo Johnny
Feb 21, 2019 09:41 AM
09BlkCrusader
Sep 9, 2015 04:47 PM
