GSM1 Fixed! Hopefully!!
Well I took my car to the dealership the car was acting really bad it wouldnt boost past 5 psi and it would hesitate badly and i was getting turbo flutter and the CEL came on and so i took it in.....they kept the car for three days and called GM tech line and finally listened to me and soldered both Sensors and rechecked and car checked out good.....I got the car back and been driving it for the past 4 days and i have had zero issues and car runs smoothly I hope its fixed for good!!!
the tech actually said its if the wires were butt connected then its bad because the sensors arent sending the right voltage back to the ECM so he called GM tech line to ensure the right Tune was installed and they told him to Solder the wires also so they soldered both sensors. They checked the voltage when they were butt connected and said it was incorrect and once they soldered both sensors the voltage was correct and they also drove the car and took snapshots of the ECM car checked out fine!!
Any idea if there is a TSB out on the soldering ?
P0236 & P0302 - the light went out on it's own - I did not clear it. At any rate, if there is a TSB then maybe I can get the 'good' dealer ( not the same that installed the kit ) to fix it.
If not, then it's back to dealer Bad to attempt a repair. I'd prefer to not have to go that route ...
Congrats on the possible fix - here is hoping I can get the same done !!
Britt
I have looked at it myself.
Translation : sometimes it works ( the connection is good ), and sometimes it don't , which truthfully gives the amount of predictibility of this issue.
Unless this question was directed to the Op, in which case - my bad.
Britt
OP, I have gms1 sensors on m ss and my car has stumbles and issues like you stated, does it only happen in the upper rpms, and did it happen when you were in second doing 40ish and when you launch it stumbles , misfire and act like **** lol. my gmst1 sensors and wiring is not soldered they are just crimped together using butts, and its hard to diagnose my car when my loggs say its all good. sometimes it wont do it sometimes it will. just curious on a more specific problem you had .. thanks alot
Yes I had all the same issues you listed it was driving me crazy
GM Performance Parts should have never shipped any of the kits with the crimp-on style splice connectors and explicitly stated to solder all wire splices. While crimp connectors might be easier for a do-it-yourself installer (which isn't going to be many due to having to get the computer reprogrammed/flashed), the only proper way to install the new sensors is to solder all connections and use a sealing shrink wrap tubing to protect the connection from the elements. This goes for any electrical connection but is even more important for something like MAP and MAF sensors which are critical for fueling and ignition calculations and requires a very accurate reading from the sensor.
As a general rule though, I solder wiring, especially on something as important and exact as a critical sensor. Dunno why GM used butt cunnectors
Im glad they finally soldered it for ya OP.
Tape won't keep water out permanently. It may help reduce the chance depending on where you live, but won't prevent it long-term. It's also not going to keep moisture out which is just as bad. If you absolutely had to use splices the best thing would be to seal it with silicone or another electrical safe sealant.
It appears to be OK . I suspect it is an issue w/ the butt crimp - one of those when temp/humidity/position/the Cobalt Gawds are all in alignment w/ true magnetic north it wigs - otherwise not.
Britt
Britt
Actually, in the old GMS1 Problems thread, the original one, lots of people posted, including myself, that if you solder the connections you should be golden. In fact, I did the install myself and soldered from the get go. NEVER had ANY issues. I had to use a different o-ring for the bottom CP and had to modify it a bit by shaving it some to make it fit but thats pretty much the only hump I ran into during the install. I just didnt like that o-ring it felt too flimsy. I then shrink wrapped each individual wire and then shrink wrapped all four together on each harness. Then I taped it and then I covered them with plastic sheathing lol
I too shrink wrapped and soldered everything. Better to be overly safe than sorry.
I am gonna guess all is still well ?
I talked to the installing dealer Friday, and am dropping the car off Tuesday A.M. If they will solder the lower wires, I will be happy.
So far as I know, the upper has never caused an issue.
This GMS1 issue has been the only real problem I have had w/ the car - mainly because it is so intermittent and therefore hard for a dealer to fix, or catch in the act.
Other than that, this was the right car at the right time given the prediction I heard of gas at $5.00 a gallon by Memorial day ...
Britt
Britt
