Has my new car been tuned? *SAGA*
Old Jun 20, 2010 | 12:35 PM
ronn's Avatar
Has my new car been tuned? YES IT WAS! DYNO, Etc>>>>
Well I decided to start a new thread on this topic. It came up on my *First Drive in My New SS* thread and then seemed to take over as a new topic there. For the *Uninitiated*..I just got this used 09 SS (8K Mi) last Friday and it *appeared* to be BONE STOCK.
I now *see the light* and what folks here have been trying to tell me. I really appreciate all the feedback. This car is programed to maintain 260HP *at all costs*. That's a pretty radical approach and one that I didn't fully appreciate or understand. People here were questioning the *unusual* boost levels I was getting under conditions that should have rendered LOWER boost. I have been hitting 20lbs boost on a REGULAR basis, where most cars (near sea level and normal temps) should be seeing much less. For example, last night at SEA level (in Burbank, Ca) where the ambient temp was 68F, I was hitting 21-22 PSI. The program is set to hit max boost only under conditions that are the POLAR OPPOSITE of that (where one would normally LOOSE BOOST!)..ie, HOT ambient temps and HIGH elevation. BINGO! Somehting fishy here. I now suspect a tune is the culprit. Another *clue* are the BRAND NEW TIRES on the car which only had 8K mi..WTF? Why would they be swapped out.....hehehe...trashed tires from hammering the rubber???
Well, I'm going to dyno the car on a Dynapack that I've used before. Dynapack can be a little *generous*, since the sheels are off the car and it measures HP to the HUBS. They say it registers at about 5-10HP more than Dynojet...give or take. Still, looking at the data, I should be seeing no more than 250ish on that dyno if it's *stock*. Anything over 260 would certainly be suspect for a tuned car.
Thing is, I was going to add the GM1 upgrade in a week or so. Now I'm putting that off. I don't wanna F$$K with this car if it's already tuned...and it's FAST already. I have clocked this car's RPMS from 4Kto 6K(62-94MPH) in 5.2 sec....FAST BABY. I know that because I've done this with two other cars (similar gearing and weight 60-90MPH there) that had around 280HP plus. My Porsche 944 Turbo was the same weight with 250 HP and did this test in 5.8 sec and it didn't hit low 5s until I did more mods and higher boost. My Camry SC did 5.2 sec and it had 260WHP with Dynopack.
Stay *tuned*
Ron
Old Jun 20, 2010 | 12:49 PM
ford's Avatar
Its probably stock
Old Jun 20, 2010 | 12:55 PM
ronn's Avatar
Originally Posted by ford
Its probably stock
Ok..why am I getting 21-22 lbs at sea level/68 outside? Is that *normal*?
OR..just tell me why you think that's within stock expectations. BTW, stock here means NO TUNE at all.
Thanks
turbaltss's Avatar
i say you have the gms1 or superchips installed already..I'm on the west coast at sea level and when I was stock I would spike at 20 maybe 21 then hold about 16-18psi.
Old Jun 20, 2010 | 12:58 PM
ronn's Avatar
HMM..yes I was talking spiking not holding there. It starts to bleed off after.
So hitting 20- 21 consistently (spike) is normal then?
Oh..definitely not GM..I looked..stock harness/sensors all the way.
Old Jun 20, 2010 | 12:59 PM
JPizzle's Avatar
Take a picture of the MAP Sensors.... That will be able to tell us if you GMS1.
And take a video of a 2nd gear pull form like 3,000 rpms, so we can see the boost & mph.
Yea. It doesn't seem like it's stock. I'm in FL, and I used to hold 16-18 stock, so....
Old Jun 20, 2010 | 01:12 PM
RooTBeeR's Avatar
subd for update
Old Jun 20, 2010 | 01:16 PM
ls1fbody's Avatar
Haz l33t wheelz.
The GM stage kit is just a flash tune into the stock computer, and some sensors. You would have a hard time visually spotting any changes.
Definitely sounds like it's possible tuned. You never know.
Old Jun 20, 2010 | 01:17 PM
JPizzle's Avatar
Originally Posted by ls1fbody
The GM stage kit is just a flash tune into the stock computer, and some sensors. You wouldn't be able to tell that there was any change.
The stock sensors look different than the GMS1 sensors, so if you look at the sensors, you can tell the difference.
And I agree, I think it has some sort of tune on there....
Old Jun 20, 2010 | 01:18 PM
Iam Broke's Avatar
My bet is on a trifecta tune that's why they left it on there.
Unless you got the Gimpsters coupe he traded a few months ago but I think he would have pulled his tune off of it.
PM him with the VIN if you like, I think his was a VR coupe with the red & black interior. He has a VR sedan now.
GMS1 sensors say Bosch on them plain as day.
Old Jun 20, 2010 | 01:20 PM
JPizzle's Avatar
Yep! But I highly doubt that it's Gimpster's..... I think it's too much of a coincidence.
Old Jun 20, 2010 | 01:21 PM
80vetteL82's Avatar
Food for thought. My GMS1 spikes @ around 23-24psi and settles to 20-21. When I was stock I rarely spiked anything higher than 16.
Old Jun 20, 2010 | 01:22 PM
JPizzle's Avatar
Really??? Do you have any CEL's? Because when I had a cel, then I would clear it, then I would spike to 25, then the computer would "learn it down" and I wouldn't really spike.
But then again I'm in Florida... Just about at sea level.
mexi_loco's Avatar
If you know someone with HP Tuners, you could just have them pull the tune off your car, and see if they can compare it to a stock ss/tc tune.
Old Jun 20, 2010 | 01:26 PM
Iam Broke's Avatar
I suggested that last night in another thread.
Old Jun 20, 2010 | 01:29 PM
ronn's Avatar
I live in So Cal..can you give their Phone # if they're in So Cal?
Thanks
Old Jun 20, 2010 | 01:30 PM
80vetteL82's Avatar
Nope, no CELs. From day 1 of my GMS1 Ive been making those boost levels.
I have had CELs from my Dejon SRI, but thats unrelated. The SRI is gone now, and I still make the same boost.
Old Jun 20, 2010 | 01:31 PM
ronn's Avatar
YEP..I have instruction booklet on GM1..
sensors are different BIG TIME. My car is NOT GM1!
Old Jun 20, 2010 | 01:36 PM
ls1fbody's Avatar
Haz l33t wheelz.
I have HPT, but you would have to buy credits before i could pull your tune.
Old Jun 20, 2010 | 01:39 PM
RooTBeeR's Avatar
not true, only need credits to edit/save and reflash a tune file as far as i remember
Old Jun 20, 2010 | 01:40 PM
SS-Performance-RS's Avatar
Thanks
as ive already commented. Ive seen 20-22 PSI after NLS'ing and im in oceanside
Old Jun 20, 2010 | 01:41 PM
ronn's Avatar
This car was from Scottsdale AZ area and had around 8K miles when turned in. It was serviced at Brown&Brown Chev Mesa, AZ in Jan of 2010 and battery was replaced (odd?). Car was then offered for sale two weeks later (Jan 31 2010) and went to Power Subaru of Scottsdale AX..then to a GM dealer (?name) in Mesa Az for sale.
VIN is:1G1AP18X797177424
Does that help as far as the car you mentioned?
Iam Broke's Avatar
I've got an '08 Model Year license, drive to the CED meet next Sat. and I'll look it over.
1badBlueberrySC's Avatar
When will people understand that boost is only a "representation" of restriction...
The stock tune files on the car limit the car to 260ft/lbs... whether that comes from 16psi or 20psi.
It doesn't mean you are tuned, you could just have a cat taking a **** or clogged causing it to have to make more boost to reach desired power levels.
Old Jun 20, 2010 | 01:44 PM
ronn's Avatar
Thanks..I get 20-21 and I've never done the NLS on it. I was coasting on FWY then I just floored it in 5th at 2000RPM (under load) and BINGO..21 lbs.
