head light help
Old May 29, 2011 | 02:09 PM
xcakez727's Avatar
head light help
im trying to buy hids for my 09 ss/tc and im not exactly sure the bulb number that i need to get for my headlights and my fog lights
Old May 29, 2011 | 02:18 PM
09SS's Avatar
The headlights are a 9007.
Foglights are H11
Old May 29, 2011 | 02:24 PM
xcakez727's Avatar
do i need to get the relay or should i be ok with out it?
Old May 29, 2011 | 02:31 PM
09SS's Avatar
Technically you should but then again I've been running HID's in both my headlights and foglights without it and they have been fine. I've had them for about a year and a half. Make sure you get rid of the daytime running lights though.
Old May 30, 2011 | 05:07 PM
xcakez727's Avatar
ill get the relay then its not that much more..how do i get rid of the day time running lights? and why would it matter?
Old May 30, 2011 | 05:22 PM
TommyP's Avatar
AWD > FWD
Just pull the fuse in the fuse box under the hood. The DRLs run the low beams at half voltage, and they play havoc with the hids, because the hids cannot run correctly without full power. They will cause them to sometimes only light up one side, or not at all, cause flickering, and a multitude of other issues. It's easier to just remove the fuse and save the hassle. If you need DRLs due to where you live or something, just flick on the low beams whenever you get in the car, or put a piece of black electrical tape over the light sensor on the dash so your headlights always come on.
ineedacobaltss
Nov 7, 2015 02:25 PM
dennis69
Oct 20, 2015 04:49 PM
Trav3480
Oct 1, 2015 08:17 PM
Sep 28, 2015 12:51 PM
