headlight issues need help
Old Apr 12, 2013 | 10:56 PM
imperialblueSS's Avatar
I had a HID headlight and foglight kit for less then I year now and all of a sudden they don't come on right away in the morning.....so my question is what shoukd I look at first for the cause..ba d bulbs, bad ballests I dunno please help
Old Apr 12, 2013 | 10:59 PM
turbosmart4's Avatar
Bad relay harness or ballast, how do they not turn on the right way?
Old Apr 13, 2013 | 07:34 PM
Every other light turns on the driving lights and interior lights but not the headlights not even when I turn the knob to turn them on
Old Apr 13, 2013 | 08:00 PM
The driving lights turn on but not the headlights? Which ones are you referring to, the turn signals??
Anyway, my headlights werent turning on (hids) and i checked the wiring harness. Check every pkug. One of mine, though it was niceley weatherproof plugged, had some corrosion on it. Since both of ur headlights arent turning on, start checking everything up to where the harness splits to find it. Sometimes electrical cleaner helps take off the corrosion sometimes its too late and u need a new harness.
If all ur plugs seem clean, check the fuses and drl fusem check for shorts.
Trav3480
Oct 1, 2015 08:17 PM
Tupp
Sep 30, 2015 08:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
SlowSaturn
Sep 28, 2015 11:03 AM
