headlight in-op
Old Oct 17, 2011 | 02:07 PM
germanSS's Avatar
headlight in-op
alright, as dumb as this sounds my headlight isnt working, all I need are reasonable suggestions for what to do next.
Circumstance: I just had my power steering assist motor changed (I think its a related problem)
What I've done: obviously pulled the bulb put it in the other side and looked at the filament to ensure its still good, once I saw the bulb is good, I checked the fuse under the hood, its also good, HOWEVER: it doesnt seem to be getting power to the fuse box (although not tested with a test light, I am fairly certain given a new fuse still wouldnt work) which makes me think the issue lays at the switch.
The switch is in the steering column (obviously) so I followed the wires from the switch down the steering column and around the power steering assist motor (which was just changed) and I dont see any signs of damage, rust, cuts, tears, splices, pinches in the wires...it all looks sound under the dash.
Any suggestions for something to search for next?
Old Oct 17, 2011 | 03:28 PM
steven2008ss's Avatar
try a new bulb regardless your filament test could have failed you
Old Oct 17, 2011 | 03:37 PM
germanSS's Avatar
will give it a shot, even though 1. the bulb works in the other headlight and 2. when i hit unlock on the key fob it comes on the low beam....just saying, i'm sure its something in the switch i just dont see anything under the dash
Old Oct 17, 2011 | 03:39 PM
BartSS's Avatar
take it to the dealer if youre under 36K and they will fix it
Old Oct 17, 2011 | 03:46 PM
N1ckateen's Avatar
just buy a new bulb and try a new fuse. simple things first. also check ur wiring harness in the headlight. very possible that one of those wires got pinched and split. happened to me on numerous occasions.
Old Oct 17, 2011 | 03:57 PM
germanSS's Avatar
take it to a dealer? thats a whole other nightmare, I'm stationed in Germany nearest legit Chevrolet dealership that will even look at a US Spec car is about 80 miles, then getting into their schedule, but I think it has 35800 or so right now
Pasierbek
Dec 10, 2015 07:22 PM
allpro666
Oct 6, 2015 08:11 PM
brickloaf
Sep 21, 2015 02:17 PM
jonnycat
Sep 19, 2015 12:58 PM
