Headlights & HID questions
Old Mar 25, 2012 | 03:30 PM
RaymondT's Avatar
Canada Headlights & HID questions
I was wondering how hard it is to take out the headlights and how to do it, im going to try to put in my new ones next weekend and i was confused where all the bolts are i could only find like 2. And i was wondering where everyone connects the possitive and negative wires for your hid kits. Since the battery is in the back do you just connect it to the alternator? or?
Thanks in advance!
Old Mar 25, 2012 | 03:39 PM
keiserX13's Avatar
BUY HID's Instructions
Pos to the red terminal on the fuse box
Neg to fender bolt
Old Mar 25, 2012 | 03:40 PM
TommyP's Avatar
AWD > FWD
Headlights are just those 2 bolts to remove. You gotta kinda push in on the inside of the light and pull out from the outside. Also pull the top clips on the grill. Once you learn how to do it it will only take a few seconds the next time. You should run your ground to the closest bolts on the fender, then attach the positive to the metal post on the fuse box, you can remove it with a 10mm socket.
brandon04
Oct 21, 2015 07:04 AM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
