help
Old Mar 12, 2011 | 10:24 AM
DerekDTP!'s Avatar
help
Just tuned my car with trifecta yesterday.. And just this morning I was driving to the store and decided to get on it a lol and now when I hit 2000-3000 rpms it starts to break up.. Any ideas?
Old Mar 12, 2011 | 10:29 AM
gotboost?17's Avatar
Nothin Stock
yea ditch teh trifecta and get hp, start wit that hehe
Old Mar 12, 2011 | 10:56 AM
Iam Broke's Avatar
Was it warmed up all the way?
You need to datalog it with Vince to fine tune it also.
Old Mar 12, 2011 | 11:01 AM
DerekDTP!'s Avatar
They sent me the tunerand I did everything the instructions said.. It flashed the engine code 33 times of that says anything.. I'm reprogramming it back to stock then re tuning ot and seeing what happens
Old Mar 12, 2011 | 11:07 AM
raynrishad's Avatar
You need to tune it. Then data log it and send the data log to vince so he can fine tune it and work out all the tweeks. Each car is different so Vince makes tweeks as needed to get your car running the way you want it.
Old Mar 12, 2011 | 11:11 AM
09CobaltSS1's Avatar
Datalogging is a MUST for any tune. The first tune you are sent is a barebones basic tune that needs to be modified to your specific car, bolt-ons, atmospheric conditions, ect. Without this process the car may (and more than likely will) run into issues. You will need to send Vince datalogs and load new tune files quite a few times to get everything dialed in just right. This is a normal process for tuning ANY vehicle. With it being the weekend and all, your best bet would be to reload the stock file until Vince can start the retuning process with you
Old Mar 12, 2011 | 11:19 AM
DerekDTP!'s Avatar
ok so i retuned it to stock and its still breaking up, so basically i have to sent the tuner back? and wait another week and what not?
Old Mar 12, 2011 | 11:20 AM
conerboner's Avatar
What do you mean by breaking up?
Old Mar 12, 2011 | 11:25 AM
DerekDTP!'s Avatar
like if i start building boost, AT LIKE 2000-3000 and up RPMs under boost it starts sputtering and ****, does fine not under boost
Old Mar 12, 2011 | 11:29 AM
raynrishad's Avatar
No, you keep the tuner. You need an SD card or MICRO SD card. You plug it into the tuner save your log file to it. Take the SD card out of the tuner and plug it into your computer. And then just email the file to vince. He'll send you a new file and you just save it to the sd card and the rest is taken care of. Vince will go into more detail with you about how to do it.
Old Mar 12, 2011 | 11:35 AM
drewbroo's Avatar
because its impossible to get a bad tune from an hp tune....
Old Mar 12, 2011 | 11:36 AM
DerekDTP!'s Avatar
ok so basically tune the car, put the SD card in, save the fine, plug into computer, sendd to vince, recieve new file, upload and i should be done?
i take it this is a common thing when tuning? cuz the car ran fine yesterday but i only drove it for like 30 mins lol
Old Mar 12, 2011 | 11:37 AM
drewbroo's Avatar
SOunds like a coilpack. If your car is under warranty, a flash back to stock take it to the dealer, they will fix it for free
its pointless to relog/retune if you have a bad coil
Old Mar 12, 2011 | 11:41 AM
raynrishad's Avatar
Drew is right in something is wrong. Tune shouldnt be having problems once flashed back to stock. Not throwing a light or anything, right?
Old Mar 12, 2011 | 11:42 AM
drewbroo's Avatar
He has a flashing CEL, im guessing its a chronic missfire by the CP (coils)
Old Mar 12, 2011 | 12:31 PM
raynrishad's Avatar
That's an easy test. Derek, the tuner trifecta sent you is also a scan tool. It'll tell you what cylinders are misfiring. check the codes. if its in just one cylinder go ahead and remeber which cylinder. clear the codes. pop your hood and swap your coil packs. swap 1 and 2 with each other and 3 and 4 with each other. take the car for a cruise and let the check engine light pop up. check the codes again. if, say #3 was misfiring and now #4 is then it was that coil pack.
Wish I could remember how to get into the scanner. Been about two years since I fiddled with one.
Old Mar 12, 2011 | 01:01 PM
DerekDTP!'s Avatar
Ok I'll deffntry that, it does it only under boost.. Car has only 28k miles
Old Mar 12, 2011 | 02:10 PM
DerekDTP!'s Avatar
Being a coil pack would it just break up under boost?
Can't figure out how to use the trifecta hand held thing as a scanner
Old Mar 12, 2011 | 02:17 PM
northvibe's Avatar
well the coil pack is whats sends the signal to the spark plug to fire...soo if its not sending enough or at all and the plug isnt firing. then yes.
I'm sure there are instructions that came with or are on the trifecta website?
Old Mar 12, 2011 | 02:22 PM
drewbroo's Avatar
email vince if you are having problems. There should be a code scanner option, under options
vince@trifectaperformance.com
Old Mar 12, 2011 | 02:23 PM
RiceCop's Avatar
Sounds like a bad coil pack or bad plugs. Did you change the spark plugs recently? Make sure they are gapped correctly if you did. If it's only doing it under boost it sounds like spark blow out. It's not your tune, that's for sure.
Old Mar 12, 2011 | 02:39 PM
DerekDTP!'s Avatar
I haven't done anything to the car except a downpipe, only had the car for about a month n a half.. Are the coil packs all the same for each cylinder
Just emailed vince
Old Mar 12, 2011 | 05:01 PM
SSlobalt's Avatar
It's not a bad coil pack, it's a boost leak. You need to run a boost leak test. Were you coming out of the 23psi tune at WOT when it started to occur?
Old Mar 12, 2011 | 05:05 PM
DerekDTP!'s Avatar
Got a code
Miss fire cyl 2
Old Mar 12, 2011 | 05:16 PM
SSlobalt's Avatar
Okay, I take that back. Most on here will disconnect the battery, take the coilpack for #2 and switch it with another cylinder, then hook everything back up and drive it to see if the issue follows the coilpack.
