help with a valve cover
Old May 5, 2010 | 03:50 PM
importkiller's Avatar
How do I get the 2 lines off of the valve cover, the ones that are facing the firewall, one of them goes to the intake the other one goes to...
Old May 5, 2010 | 05:29 PM
peachpuff's Avatar
The steel braided ones? For the one in the center you need a fuel line disconnect tool, most automotive stores should carry it. As for the one on the side its pretty much impossible unless you want to damage it.
Old May 5, 2010 | 06:27 PM
SSlobalt's Avatar
Somebody on here got it off using two small flatblade screwdrives that he bent the ends on. I don't remember who that was, though. It was the vent line coming from the turbo.
Old May 5, 2010 | 08:11 PM
I remember that post but I searched for 1 hour with no success.
Old May 5, 2010 | 08:13 PM
Gestapo007's Avatar
omg that one is a nightmare! i painted my valve cover and just taped it up. I unbolted the 10mm bolt from the turbo, just look back there and youll see where it goes, then where it connects into the turbo is a pain in the ass to remove too. Its really lodged in there. Tried prying with clips tools and everything and finally got it out. Lost that 10mm bolt too and had to use some cheap bolt that doesnt fit well when reinstalling. Called dealer and they cant get it without ordering a whole turbo lol.
Old May 5, 2010 | 08:18 PM
My plan is to do a VHT red wrinkle coat paint job, Can I leave the PCV and other lines on it even though it needs to be in the oven for 20 minutes at 200 degrees?
Old May 5, 2010 | 08:32 PM
SSlobalt's Avatar
Your motor runs 200 degrees all day long, so I don't think it should be an issue.
Old May 5, 2010 | 09:16 PM
Yeah, I was concerned about the plastic retainer clip on one of them.
Old May 5, 2010 | 09:40 PM
Gestapo007's Avatar
your fine. ever baked headlight?
Old May 6, 2010 | 12:51 AM
Yah...never thought of that...good point...I can't wait to do this I am soooooo excited to see how the wrinkle red comes out!
Old May 6, 2010 | 02:49 AM
SSlobalt's Avatar
It'll be ricer, but good luck.
Old May 6, 2010 | 08:53 AM
peachpuff's Avatar
VHT wrinkle red? Look here.
Old May 6, 2010 | 10:31 AM
Gestapo007's Avatar
the wrinkle looks good, its not ricey
dennis69
Oct 20, 2015 04:49 PM
HEATON
Oct 16, 2015 07:21 PM
CobaltSS 16
Sep 29, 2015 01:53 PM
Trav3480
Sep 28, 2015 02:46 PM
SlowSaturn
Sep 28, 2015 11:03 AM
