How do you turn off the TPMS sensor warning in gauge display
Old 01-14-2010, 03:50 PM
ptroy's Avatar
Recently put on winter tires and rims, and am foregoing the TPMSs. How do I remove the warning/alert from the gauge? Anyone know?
Old 01-14-2010, 04:04 PM
DarkCobalt13's Avatar
dealership will have to remove the light with a GM techII I believe
Old 01-14-2010, 04:05 PM
importkiller's Avatar
black tape
Old 01-14-2010, 04:30 PM
SSlobalt's Avatar
Once it comes on, you can just clear it with the bottom left button on the steering wheel.
Old 01-14-2010, 07:04 PM
Hamrhead's Avatar
Originally Posted by importkiller
black tape
^What he said. A small piece of electrical tape should work well until Spring.
Old 01-14-2010, 07:29 PM
blownss06's Avatar
Air tires up!
Old 01-14-2010, 11:27 PM
I assume he is running winter tires w/o tpms
Old 01-14-2010, 11:34 PM
Maven's Avatar
theres no way to clear it so it doesnt return
Old 01-15-2010, 12:22 AM
slapbetcommissioner's Avatar
I've found a screw driver and a tiger torch work well.
Step 1 Heat up the screwDriver till it's red hot.
Step 2 insert through plastic and wiggle.
Old 01-16-2010, 10:39 AM
Gimpster's Avatar
As much as *I* hate TPMS systems, ... really glad my wifes car has it. Shes so oblivious to the world. I'm starting to think I need to get into 60's muscle cars or something. All of the electronic nanny systems annoy me.
Old 01-16-2010, 12:27 PM
Maven's Avatar
Yeah, but she still has to pay attention to them. I really believe that vehicle speed should be limited when the warning is on.
My wife will tell me **** like "the tire light has been on for a week........"
Old 01-16-2010, 01:43 PM
Boosted_Cobalt09's Avatar
^^^ yeah i completely see what your saying. i had to recalibrate all my sensors to accept my winter tires and then i get to redo come summer to read the other sensors.
Old 01-16-2010, 11:39 PM
JPizzle's Avatar
Off topic... How do you reset your sensors when you rotate your tires?
Old 01-16-2010, 11:41 PM
Bades's Avatar
the dealer has to hook up the scanner and put it in recal mode then use the lil trigger tpms setter to do it lol
at least that how it wrks on the subys lol
Old 01-16-2010, 11:43 PM
gdubs's Avatar
Check your owners manual. Explains it easier than anyone can typpe it
Wrong.... welll.... right...but wrong.... Read your owners manual. Can be done right in your garage with your key fob
Old 01-16-2010, 11:49 PM
JPizzle's Avatar
Ah! Ok. I will have to read it. Thank-you!!!
Old 01-16-2010, 11:57 PM
Zander916's Avatar
What does the TPMS sensors look like? The ones I think I've seen are kind of band on the inside of the wheel?
I'm just wondering because I have one that reads from full pressure to 0psi off and on about once a minute. It's beyond annoying at this point. I could get past the light but having it go on and off all the time with the message is just insane.
Can a DIY'er replace them?
Old 01-17-2010, 12:10 AM
steddy2112's Avatar
It is on ours
105
Old 01-17-2010, 12:13 AM
Bades's Avatar
hey at least ur not getting the "my car is almost out of oil... u need to pout sum in and change it .... ys that babe?? the dash said i only have 18% oil left in the car...."
Old 01-17-2010, 12:17 AM
Chad92's Avatar
It's about as simple as replacing the valve stem. I broke one changing a tire on a rim with TPMS a last year at my old job. They're $50 each to repair and very easy to break off the valve stem when you're changing tires.
Old 01-17-2010, 12:28 AM
Zander916's Avatar
Sweet! Thanks for the excellent info!
Old 01-17-2010, 03:07 AM
Maven's Avatar
Originally Posted by steddy2112
It is on ours
105
I mean like 40mph
Old 01-17-2010, 03:18 AM
steddy2112's Avatar
I mean like 40mph
Where's the fun in that, I wanna be able to have a blow out and do over 100 mph
This is America gaddammit
Old 01-17-2010, 09:24 AM
Force's Avatar
I just got used to having it on all the time. The only annoying part is having to clear the SVC TIRE MONITOR message every time I fire the car up. The light doesn't bother me since I kill the TCS every time I drive the car anyway, so it's just an extra one.
Old 01-17-2010, 09:46 AM
DNewman's Avatar
You can reset it by doing this:
1. Turn ignition to on position, but do not start the car
2. Hold the lock and unlock button on your key fob for a few seconds and the horn will sound twice and the DIC will say Tire Sensor Relearn.
3. Start at the left front tire and either remove or add air until the horn sounds.
4. From the left front move to the right front, then right rear, then left rear, doing the same to each until the horn sounds.
5. When you are finished with the left rear the horn will sound twice letting you know the relearn is complete
Quick Reply: How do you turn off the TPMS sensor warning in gauge display
