How much boost in cold weather?
I was driving around today and noticed that I could only get about 12 to 13 PSI of boost. Is this normal when it's cold out (37 deg.) I seem to remember getting more like 15 or 16 when it was warm out.
yup that's normal dood, GM made this car smart so it always makes 260/260 no matter wat the weather conditions or altitude ect ect.
Can anyone confirm that they also only get 12-13 PSI when it's that cold out?
I make about 14.5PSI right now with the temperature just above freezing, the altitude here is also about 5000FT. Also the max I've seen is about 18PSI
Correct I'm originally from michigan before I was tuned drove back and only ran about 15 psi in michigan ran 18-20 here in 5,000 ft elevation. Since hahn tune it's 25 psi no matter if it's 20 degrees or 100. ran tune since August.
but it makes sense to boost less in the cold and make the same power.
Should cold weather affect gas mileage?? I know it will run leaner until the engine is up to tempature.
I am not sure if the winter blend gasolines have come out yet or not but I was expecting to easily get 30-32 mpg on the hwy(espcialy since the EPA made the rules stricter). Most of the time I will set the cruise at 70 and it will usally average 28. However if I follow someone i jumps to the low-mid 30s.
Just wondering if all TC were similar to this.
How does the computer make up for a lack in 02??
They have altitude correction tables for forced induction cars because they too---suffer--and you can correct to sea-level.
1WhiteSSTC sent me this article which explains it best
http://editorial.autos.msn.com/artic...umentid=473407
to paraphrase:
GMPD took an innovative approach to the gutsy four-cylinder. Instead of tuning to a prescribed boost level, the ECU targets a constant torque number using a variable boost strategy.
Ambient air temperature and absolute air pressure are two of the main tuning parameters. So on a cool night with dense air the turbo may only need to produce 13 psi to hit the mark. But on a hot summer day it will unleash up to 21 psi in its efforts to deliver the goods
ok I am sold--if GM designed it to maintain HP in high elevations by varying boost levels--good enough for me
I just need some explanation. I don't beleive every forced induction engine does the same thing though.
bet he was talking about density altitude.
to paraphrase:
I just need some explanation. I don't beleive every forced induction engine does the same thing though.bet he was talking about density altitude.
