I believe we have a problem Houston.....
#51
ah good ol ZZP
you could have told them you'd only ran it at 15 psi its entire life and they'd say "thats too much, we run them at 12-13 psi only"
******* shady bullshit.
FWIW, my journal bearing turbo on my STi states max boost at 2.5 bar with their performance thrust bearing. so they can handle quite a bit.
2.5 bar = 36.2594 PSI
Lucky for you, journal bearing turbos are cheap to rebuild.
#52
You're not the only one who has had this warranty issue with this turbo. ZZP also denied someone else thats on facebook. They are really dropping the ball on this turbo.
#54
I had put the Z54 on my wish list for when my K04 fails (or my 09/08 LNF does), but this thread is changing that plan. OP, I hope ZZP does the right thing for you. They need to specify any limits they think these units have before taking money from people and giving them the impression that common boost levels are supported.
#55
I'm hoping they do good by me. Now my problem is time. I don't need the car, I just have to find the time between how slammed we are at work and the family(got a newborn) to rip it out and send it in.
#56
Hey Idk if this will help you or not but I picked up the same turbo from zzp last summer. I specifically emailed asking them if the turbo an all could handle 26 to 29 psi. They told me yes as long as I had the proper fueling mods. I still have the email if you'd like to see.
#57
#58
So, just to keep this updated....
Between work and a newborn around the house, I finally found time to pull the turbo tonight to ship back to ZZP. There is quite a bit of shaft play up/down/left/right, enough to where just by touching the wheel you can make it touch the sides of the housing. The big no-no though is the ~5/8" movement in and out. The turbo is definitely f*cked.
Shipping on Monday, we'll see how it goes.
#61
I think the eventual outcome here speaks more to if they will stand behind their product, and if not, why;
I find it astonishing and disappointing that it seems as though aftermarket turbos are almost good for nothing more than using for one season to get some sort of status (hp or e/t), and then they die;
these turbos, before final assembly are, by my understanding, made from the same suppliers of OEM turbos - so why the apparent quality difference.
... remains subscribed.
#62
#63
maybe they only sold 50? 1/50 is 2%.
thats an acceptable limit for failures in most companies, we aren't borg warner. we aren't ZZP. we dont know their volume
while i dont like ZZP, the real test will be if they warranty it for him. so before we bash them to oblivion, lets give them a chance to make it right
Tdubbs (01-29-2018)
#65
its 1 person out of how many ZZP has sold? Lets guess. pretend they've sold 100. 1/100 is 1% of failures.
I know there are a few others that had their Z54 blow recently, but without knowing how many have been sold it's impossible to guess failure rate. Always remember, people are more likely to voice their opinion when things go wrong vs everything is dandy.
That being said, I'll have to agree with leemanfor. I may be displeased with ZZP currently, but I'm not about to start slamming them yet. I thought I read on Facebook someone got theirs warrantied, so there's hope.
I bought one of the first batch they released, maybe there was an issue that was "silently" updated on newer ones, and a hope for the best on the ones already in the wild. (personal conspiracy theory, ignore at your discretion)
#66
I hope they come through. Even if you are on it hard I would still expect a cheaper version of the 6758 to make it a year. It's not like it's a $500 turbo bay rebuild, it's brand new. Maybe they need to use a different bearing, and I bet they look pretty hard at what that assembly looks like since it's failed. They won't want a bad reputation on that turbo or their business name.
#67
#68
I remember a time when GM's CS alternators hit a failure rate of 3 tenths of one percent due to bearing failures and heads rolled. I think GM is still at 5-year/60,000-miles on their powertrains, turbos included as long as they are left stock. With that said, It's rare to see any type of warranty on aftermarket performance parts.
#69
So just another quickie update. I haven't been told explicitly my turbo is being warrantied, but I also haven't been told it wasn't, but that's not the point of this post.
Matt from ZZP had asked me if I was running the stock or an aftermarket bpv in the turbo(I was, I never got around to taking my Forge out of my stocker), and he let me know that they had issues with the spring stiffness in the bpv's of their original units that could cause flutter/surge. I never noticed any surge with mine, but it did flutter here and there, but I chalked that up to the normal "zfr flutter" I've read about on here. He said they have updated them to a softer spring to alleviate the issue. Just thought I'd share that tidbit of info with y'all.
Edit: Just noticed that both the ZFR and Z54 are currently out of stock. I wonder if they're having to tear down some turbos for parts to rebuild the few that had issues recently.
#75
i would assume for warranty issues they would be rebuilding your turbo instead of just giving you a new one.
what they are telling you does make sense, if they have discovered the bypass valve isnt working as designed and its causing compressor surge, it will hurt the turbo. in the end its their problem, your using the turbo as it was sent to you, didnt change the bypass valve, and they didnt specifically say dont run it over X boost level.
id guess that if this is a recent discovery and they have made this design change (softer spring) they have taken all their turbos off the shelf to change the spring before sale, and thats why they are all out of stock.
also for what its worth, when i bought my efr 7670 i enquired about the bypass valve. i was told the internal bypass works fine on the small efr turbos, and if i was going to keep the boost down on my 7670 it would be fine, but overall it would be better to run a blow off valve on the charge pipe. this makes sense to me seeing as all efr turbos run the same recirc valve, and its pretty small compared to most blow off valves.
