i wanna run e85
i wanna run e85
its a 08 lnf n bone stock aside c.a.i , catted dp and 3 bar maps. now what kind of power should i expect to see? do i need to do anything to the internals of the motor? and as far as i know all i need is the opel injectors and aem high flow ethanol pump then a tune to run on it right?
You don't really need the injectors or the pump to run e85
What you would need is a fuel lobe cam and get e85 safe orings for your injectors.
I would just recommend you going with e47 all you would need is a tune and changing your injector orings wouldn't be a bad idea
