Installed genuinesaab aluminum shifter bushings
Old 12-29-2009, 03:30 PM
jpower102's Avatar
Thanks for sharing .. I'll order mine !
Old 12-29-2009, 04:37 PM
umrdyldo's Avatar
http://www.genuinesaab.com/catalog/p...658610be09c0ed
So has anyone tried the short shifter as well
I wonder what it's like with both.
Maybe i should drop it off some day and try it out.
Old 12-29-2009, 04:58 PM
northvibe's Avatar
Originally Posted by metroplex
Where can I find the TWM bushings? This intrigues me especially if it is a simple mod.
Twm performance website, they are also a vendor on this website. If yu are a student or in thr military you can usually get a discount as well.
Old 12-29-2009, 05:10 PM
umrdyldo's Avatar
Seems like TWM doesn't have a bushing kit for Cobalts yet.
Old 12-29-2009, 05:43 PM
ecotecon18s's Avatar
uh....you must have missed it...
...unless you mean for the base/LT/LS cobalts..
Old 12-29-2009, 06:00 PM
jpower102's Avatar
http://www.twmperformance.com/bushingkits/index.htm
Old 12-29-2009, 06:02 PM
Whoop there it is.
Old 12-29-2009, 10:38 PM
tom.g's Avatar
There are shift cables attached to the transmission, and the housing is attached to the body of the car. GM chose rubber bushings for a reason. Although I am intrigued as to why some people are claiming it makes the shifter feel more rigid, and I'd like to know the actual difference - is it a major change?
I wouldn't say it's a major change but it does make a difference. It really is hard to describe. It firms up the whole shifter assembly from wobbling around every time you change gears, and it just makes everything seem firmer/tighter more precise. For $20 and 15min of work you might as well give it a shot.
Old 12-30-2009, 12:15 PM
jpower102's Avatar
Good question .. they are cheap .. I wonder if its worth it..
Old 12-30-2009, 12:27 PM
Black08SSTC's Avatar
Originally Posted by northvibe
I put metal shifter bushings in my ms3 and it was night and day difference. Doesnt TWM make bushings for the SS? if this OP isnt going to say **** then **** him, TWM has bushings for $25.
It makes the shifter have a more direct feel, and pushing into gear easier. I didnt have vibes when I had mine in
i just ordered my TWM base bushings yesterday! i cant wait to install them and take the TC for a quick spin. it be my first one in about 2 months lol
Old 12-30-2009, 12:37 PM
  #36
umrdyldo's Avatar
I'm trying to figure out how that short shifter piece works.
Old 12-30-2009, 12:43 PM
  #37
it takes the shifter and moves the way it engages on the bottom.
Here is a very crappy paint drawing of the stock shifter on left vs say a TWM or Hurst on the right. Aftermarket is straight with a ball on the bottom. Stock is bent at bottom and connects on the side
Old 12-30-2009, 04:44 PM
  #38
northvibe's Avatar
No umd is referring to the genuinesaab sts which isn't a full sts it looks like a add on. I thought there was a thread where someone was gonna try it?
Old 12-30-2009, 11:18 PM
  #39
importkiller's Avatar
It looks like the genuine saab short shifter replaces the lattitudinal connector to the cables so that the throw is shortened.
Old 12-30-2009, 11:32 PM
  #40
Gixxerboy02's Avatar
sub'd
Old 12-31-2009, 12:36 AM
  #41
jarhead's Avatar
Yes That was me I posted in the other thread once I installed both the bushings and the short throw works great took about 40 mins tops to do, The difference with both is amazing really shortens the throw up and simple to do just cut the side part off at a certain length put the new straight part on, a set screw and some loctite provided even though its a real tight fit wouldn't come off even w/o a set screw, turn the connector from the side to the ball now on the bottom instead of the right side. Keeps the stock shifter and doesn't burn ya in the summer with a metal shift knob, You can also add a different leather knob if ya like to the stock shifter.
This is what is cut off.
Old 12-31-2009, 02:58 PM
  #42
jpower102's Avatar
Ordered the bushings yesterday and received them today .. wow that was fast!!!!
Old 12-31-2009, 03:55 PM
  #43
shadowfaxss's Avatar
Nice information......will have to purchase two sets
Old 01-01-2010, 10:57 AM
  #44
jpower102's Avatar
Has anyone seen the instruction booklet ... it isn't very clear on how to place the actual new bushings .. anyone got a pic? .. If not, I guess i'll just have to see it for myself
Old 01-01-2010, 12:56 PM
  #45
pull the rubber stock bushings out of the shifter base, put the new bushings on the studs the base sits on, reinstall the base, put the washer on top, then bolt it all back down. Done.
Old 01-02-2010, 11:35 AM
  #46
jpower102's Avatar
Thanks!!
Old 01-04-2010, 07:31 PM
  #47
jpower102's Avatar
I installed the kit today .. went super well.
I can feel a slight difference... the feeling is just a bit stiffer
Old 01-04-2010, 07:52 PM
  #48
northvibe's Avatar
twm bushings?
Old 01-05-2010, 09:55 AM
  #49
jpower102's Avatar
twm bushings?
Yeah .. I would not say its night and day .. but there is a difference
Old 01-06-2010, 03:07 AM
  #50
bmaynard06's Avatar
So has anyone else tried their STS?
I'm not sure if this will hurt or help me. That is did you guys say it relocates the the longitudinal connector? My problem was once already I have cracked the bushing that connects the shifter to the forward and backward connector of the shift linkage. So i'm wondering if this might help me?
Any suggestions?
Quick Reply: Installed genuinesaab aluminum shifter bushings
