jzehren11s' Turbo Build---What do I get?!?
Old Aug 21, 2012 | 06:02 AM
jzehren11's Avatar
its between these two really:
DVC-30 methanol Injection Kits : DevilsOwn water Injection
2.5 Bar Stage 2 Water Injection Kits : DevilsOwn Methanol Injection
still need a tank though...what size tank...2 gallon?
Old Aug 21, 2012 | 06:14 AM
FrossB's Avatar
Thread Killer
I would say 24 psi is a good number to start at. And yes 10psi is pretty average for a meth kit to kick in.
Me personally, when i do my meth kit im going to go with an AIS kit. They are a little more expensive but seem worth it!
The Best Water injection system and water methanol injection systems at AlcoholInjectionSystems.com
Old Aug 21, 2012 | 11:34 AM
jzehren11's Avatar
looking at $3500 so far for my build
DVC-30 Stage 2-------------------500
--2.25 Gallon Sumped Tank
WERKSracing WR-2 LNF Turbo Upgrade-2025
Trifecta Tune/HP Tuners(not sure)----------------------300/500
ZZP LNF Upper Intercooler Pipe-------200
KY Clutch with TOB-----------------400
should I get the GMS1 sensors or is that not needed???
Old Aug 21, 2012 | 12:29 PM
ei3dag3's Avatar
what about rear main seals, axle seals, clutch pipes, transmission fluid and a flywheel?
that adds quite a bit.
Old Aug 21, 2012 | 12:32 PM
jzehren11's Avatar
I NEED new seals?
****, forgot the alum flywheel(which one do I get?!?!)
Ill be posting more lists for sure before I buy everything
Old Aug 21, 2012 | 12:49 PM
ei3dag3's Avatar
I NEED new seals?
don't NEED new seals.
but which would you rather do? replace them and not have any issues, or not replace them and have to do the clutch install again?
flywheel - go to zzp's site. just buy a stock lnf one.
Old Aug 21, 2012 | 12:53 PM
jzehren11's Avatar
i would like alum. or is it not that big of a deal
Old Aug 21, 2012 | 12:55 PM
jzehren11's Avatar
seals and all that would be from crate engine depot?
Old Aug 21, 2012 | 12:56 PM
ei3dag3's Avatar
just get the stock lnf flywheelfrom zzp. you'll be fine. yep. CED has all of that shizz.
i just did a clutch install this weekend and everything worked out great. ky stg 3 felt just like my stock clutch. i have one chilling in my garage for now, but need to buy the rest of the stuff.
Old Aug 21, 2012 | 12:57 PM
jzehren11's Avatar
kk, ill add it to the list...
Old Aug 21, 2012 | 01:04 PM
  #36
jzehren11's Avatar
cant find axle seals, clutch pipes
Old Aug 21, 2012 | 08:24 PM
  #37
me6894's Avatar
Why would you replace the rear main seal if its not leaking? Chances are it will leak from replacing it with the incorrect tool before it will leak from the factory on an ecotec engine... pretty rare.
And axle seals, if you do put it together and find it leaking, they're easy enough to do later that I wouldn't spend the extra 25 bucks if you don't have to.
Same thing with transmission fluid unless you have higher mileage.
Old Aug 21, 2012 | 09:01 PM
  #38
C_A_D88's Avatar
Rear main seal went bad on my 2.2 at 60k km
Old Aug 21, 2012 | 09:56 PM
  #39
ei3dag3's Avatar
tell that to my friend who replaced his clutch and had a rear main seal leak a few months later and had to pay all over for it to be fixed.
also you do realize that the transmission fluid spews out when you crack open the transmission? thats why you drain it. if you're going to drain it you might as well replace it.
also OP CED does have the seals.
we ordered them last week.
Old Aug 21, 2012 | 10:10 PM
  #40
cmiller8006's Avatar
Easiest answer is to goto zzperformance.com and you will be set.
Old Aug 22, 2012 | 09:19 AM
  #41
AARON-SS-TC's Avatar
looks like on your psi and meth on 93 gas will be more like 450whp with full bolt-ons...
Old Aug 22, 2012 | 09:59 AM
  #42
ei3dag3's Avatar
i'm sure he would if he wasn't in germany.
Old Aug 22, 2012 | 11:53 AM
  #43
jzehren11's Avatar
I can order from them...I just gotta make sure they ship the stuff out USPS.
I cant find all the parts I need once I replace the clutch though
Old Aug 22, 2012 | 12:30 PM
  #44
DirtyBalt09's Avatar
I wouldn't get an aluminum flywheel.
Old Aug 23, 2012 | 01:21 AM
  #45
Frogstofall's Avatar
IMO, doing the seals is a waste unless you actually have a problem. I've never seen them go bad or heard about it other than just now on this one.
You only need about 1 bottle of trans fluid to top it off from the spill when you remove the axles. Separating the trans from the motor itself doesn't make a difference. Its removing the axles that does it.
Old Aug 23, 2012 | 01:30 AM
  #46
FrossB's Avatar
Thread Killer
Yes the seals are a waste unless they are leaking. I would suggest just using a OEM flywheel too rather than a lightweight one....that is of course if you go with the KY clutch. Or like me i just resurfaced mine cuz it didn't have alot of miles on it.
Old Aug 23, 2012 | 02:06 AM
  #47
jzehren11's Avatar
Yes I will more than likely go with a KY stage 3 or 4. Not really sure yet.
Old Aug 23, 2012 | 05:04 AM
  #48
FrossB's Avatar
Thread Killer
Well i have the KY stage 3 and daily drive it with my setup. (407hp/391 trq was last dyno) but then i switched to E30 blend and picked up a good chunk of power and trq and my clutch started slipping so 450trq is definitely the limit on the Stage 3.
Old Aug 24, 2012 | 02:17 AM
  #49
jzehren11's Avatar
so probably should go with a Stage 4?
Old Aug 25, 2012 | 08:05 PM
  #50
jzehren11's Avatar
Looking at maybe getting a Treadstone kit! Wanna just build it to like 450. Then build internals later so I don't have to drop the whole engine again to put a bigger turbo
