K&N Intake for SS/TC
Old Jun 11, 2010 | 10:21 AM
  #701
northvibe's Avatar
from what I've heard you should be at 0 as much as you can but a slight negative (-) is better than a slight positive(+).
Old Jun 11, 2010 | 10:23 AM
  #702
Adam84's Avatar
This intake is sounding promising will definitely be in for the group buy.
Old Jun 11, 2010 | 10:37 AM
  #703
Stamina's Avatar
^this
Old Jun 11, 2010 | 10:45 AM
  #704
CudaJoe's Avatar
Originally Posted by ford
Thanks! i was actually going to ask what you had found to be best so far, as i dont have tuning software to monitor the car. I simply am going off of throttle response and then backing it off a little so as not to run it lean or anything. right now i have it at 12:30 and it idles smoooooooth and has less surge than it did stock.
That thing is scary loud the first time you turn the car on haha.
oh yeah! On a cold start with the hood up, it sounds extremely loud for vacuum. That would be the Open circuit... Its what it sounds like under your hood at WOT. You just cant tell cause you hear the exhaust and the car is moving. You can hear that vacuum noise at about 0 psi from inside the car as well. I thought it was a grinding noise at first.
Old Jun 11, 2010 | 11:21 AM
  #705
Permafried-'s Avatar
Sounds like a supra with a little turbo bark? Its the first modded TC balt i know of, so im not sure if it sounds like the rest of them.
http://www.youtube.com/watch?v=nnnFPsHzBJE
Sounds like a dog swallowed a duck and it's trying to get out . Still in for the long term results, but it looks like K&N definitely did their research in this case instead of just dumping a tube on the turbo
Old Jun 11, 2010 | 11:37 AM
  #706
F_Imports_09tc's Avatar
Makes me want to bring out my inner ricer even though Im still stock
Old Jun 11, 2010 | 11:42 AM
  #707
SS_carnatic's Avatar
Questionase:
So everybody take off their - negative battery terminal?
Did it screw with your GMS1 or security system at all? lol figure it won't as they are both loaded software on the computer....kind of like turning off your desktop....doesn't delete software....like GMS1
^^ i know, i know....i just want piece of mind haha^^
btw: would that reset oil life monitor?
Old Jun 11, 2010 | 11:50 AM
  #708
drburns's Avatar
Well, this intake definitely looks promising, and sounds pretty good. I'd be interested once I see some more info regarding gains on full bolt on tuned cars, and see how tuning for the intake goes.
Old Jun 11, 2010 | 11:58 AM
  #709
With FTs being in the ranges people are reporting and 0 evidence of surging or fluttering under open loop or idle/WOT, this may very well be the first intake that does NOT require tuning to work correctly with the stock or GMS1 tunes. That doesn't mean you couldn't get some more out of it by putting time into it but I've been holding out for an option that will show some gains (even if slight) without having to invest in a 2nd ECM and a custom tune...at least for the time being .
Old Jun 11, 2010 | 12:06 PM
  #710
Originally Posted by SS_carnatic
Questionase:
Yes, anytime you add something to your car unhook the battery to resest the ecu. It will not mess with any of your data(oil life, etc..) It's just resetting fuel trims etc
Old Jun 11, 2010 | 12:14 PM
  #711
This is where I get confused. Is it really necessary to reset the LTFTs? Will they not correct themselves over time based on the STFTs the vehicle sees over X number of miles after the intake is installed? I understand it may throw a CEL if they're horribly out of whack but are LTFTs not in place for this very reason...adapt to the vehicle's operating environment to determine what is "normal" for it in its surroundings without requiring a reset?
Please be gentle with the responses . I've been investing a **** tonne of time reading/researching/learning on everything to do with tuning, how the modules all work/interact, etc but there's some things I might not be quite straightened out on yet .
Old Jun 11, 2010 | 12:16 PM
  #712
swazzees's Avatar
wait for group buy.....im in too man
Old Jun 11, 2010 | 12:20 PM
  #713
ford's Avatar
Questionase:
Yes, you should always unhook the battery as well. if the car deleted software each time it lost battery, you would lose a tune if you left your lights on.
Unplugging the battery is not for resetting the ECU so much as not ruining any electrical components while working on the car. I had a friend leave the battery hooked up while working on his neon... it made a loud pop, i laughed, and the car wont start anymore
People really should not psych themselves out worrying about this intake. It has about 200 miles on it already and no fluttering, collapsing, driveability issues to speak of.
Old Jun 11, 2010 | 12:22 PM
  #714
That's what I thought, but wanted to be sure I wasn't completely missing something. Thanks !
  #715
ford's Avatar
And if people are worried about anything i can take vids at idle, low speeds whatever. The car behaves better than it did with a stock airbox. One very happy customer
Plus the sound makes you smile each time you get on it.
Old Jun 11, 2010 | 12:24 PM
  #716
CudaJoe's Avatar
You dont have to reset the LTFT's. I have tried it numerous ways now. I've gone from a 9:00 position and got -8.0 LTFT's then moved the filter to the 2:00 position and watched the LTFT's creep into the positives. After about 5 mins, I was at +6.5, lol. You would think the happy medium is about 11:00 but I think its about 12:30.
Another time I reset the PCM by unplugging it and I watched which way the LTFT's floated from 0.0
Old Jun 11, 2010 | 12:25 PM
  #717
steddy2112's Avatar
Yeah sorry, just did some driving. Its smooth as **** at idle, i couldnt drive it as i broke my glasses and am blind as ****, so my brother was in the car. Comes on smooth and havent had any issues so far. It is LOUD though. It pulls pretty good, no erratic idle, no CEL and we put about 80 miles on it
http://www.youtube.com/watch?v=ZRJQ7WtdLFY
Oh and the 09 and the K&N had the correct bracket, no modification needed or a new bracket. Install was a breeze and it fits amazingly well.
Do you have a BOV?
Old Jun 11, 2010 | 01:36 PM
  #718
ford's Avatar
No, just GMS1 and K&N SRI, MPx downpipe and exhaust soon though.
Old Jun 11, 2010 | 01:39 PM
  #719
Thanks to you as well...both you and ford confirmed I'm on the right track so all this reading must be payin' off .
Old Jun 11, 2010 | 01:46 PM
  #720
CudaJoe's Avatar
Originally Posted by steddy2112
Do you have a BOV?
Thats pretty wild huh? Mine makes a similar noise but I only boost to 15psi so mines a quick yelp not that slightly drawn out longer yelp, lol. Really does sound like a BOV with some Flutter.
Old Jun 11, 2010 | 01:54 PM
  #721
Cobalt08tc's Avatar
so are the sri from k&n on back order or what cus their website has said out of stock for a while now
Old Jun 11, 2010 | 02:04 PM
  #722
Whitty's Avatar
they made 30 units and all were sold they should have more ready soon read this thread and u would know
Old Jun 11, 2010 | 02:09 PM
  #723
steddy2112's Avatar
Sounds like it's fluttering.
Fluttering isn't AS BAD as some people make it out to be...and it could be his car...I wanna hear a few more cars first.
Last edited by steddy2112; Jun 11, 2010 at 02:09 PM. Reason: Automerged Doublepost
Old Jun 11, 2010 | 02:11 PM
  #724
CudaJoe's Avatar
Its the reward we get for pulling the trigger and getting the intake, lol.
mine doesnt make that fluttering noise, and im on the stock tune. I think thats just the noise the stock BPV makes with the GMS1.
Old Jun 11, 2010 | 02:16 PM
  #725
The BPV is louder on the GMS1, I can vouch for that but much but not sure about the noise itself 'cause it's heavily muffled by the stock airbox. I'm accustomed to hearing it open/close relatively quickly depending on weather/ambient temperatures.
