Launch Control
Old Dec 30, 2010 | 01:02 AM
SS-Performance-RS's Avatar
Launch Control
So ive had this car for 7 months now and I must say it is my first stick car. I mean I had driven stick before but never owned a stick car. Been told im a good driver and decent launcher. So today I decided to try out launch control for the 1st time. I never tried it before since the mixed reviews. I must say its a nice advantage to have. 1st run. Put it in LC and let out the clutch rapidly. Got some wheel spin until about 3k then it spun again a lil at about 5-6. It was good.2nd run was pretty much the same. So my question is what do you prefer? Do you think LC is good to use in an actual race? My problem with normal launching is that I dont let the clutch out fast enough or I let it out to fast.
Old Dec 30, 2010 | 02:31 AM
Stamina's Avatar
I tried it once and only once not too long after I got the car. It was a tire-burning, clutch-roasting, rev-limit-tapping mess. I've never used it since.
I launch myself now everytime and usually do an RPM between 2000-2200RPM. I tend to have much better success that way. If you work the clutch well, you can spool the turbo off the line as it is and maintain the balance between power and traction until you're out of first gear and on your way. The 4700-5000RPM range that the LC tends to put you in is pretty much useless.
On that note, Trifecta is working on releasing an adjustable RPM LC capability. That would then make LC useable, as you could then set the RPM for something more useful.
Old Dec 30, 2010 | 02:38 AM
JacBlackSS/TC's Avatar
yeah the launch control pretty much is useless and you get better times without it like stamina said its set entirely too high which i don't understand why gm did that 5k is too close to 6300
i tend to try to launch around 2k and you have to side-step or slip the clutch as oppose to dropping it, when you drop you just sit at the line and spin just like you described
but i can't wait for vince to come out with the adjustable launch control thats gonna work wonders for us
Last edited by JacBlackSS/TC; Dec 30, 2010 at 02:39 AM. Reason: Automerged Doublepost
Old Dec 30, 2010 | 04:53 AM
RyRidesMotox's Avatar
Launch control is a total fail at the 1/4 strip... I tried it once on the street and it was useless.
Old Dec 30, 2010 | 08:39 AM
raynrishad's Avatar
5k RPM is just useless. It's way too high to launch at. Stock it gives wheel spin or starts bucking the engine. If you're putting out mroe power prepare for total fail.
Old Dec 30, 2010 | 08:07 PM
isnt side stepping the the same as droppin the clutch?
Old Dec 30, 2010 | 08:27 PM
TractionControlWTF?'s Avatar
launch control on these cars are ****.
batboy's Avatar
Once you're tuned, it's totally useless. It'll just sit there and roast the tires. There's an old saying... if you're spinning, you ain't winning.
Old Dec 30, 2010 | 09:56 PM
gotboost?17's Avatar
Nothin Stock
^^^ and if u NLS its even worse....i like ESC off and play wit it
Old Dec 31, 2010 | 05:02 AM
I'm to scared for my clutch if I NLS or use launch control
Old Dec 31, 2010 | 05:22 AM
HenryF's Avatar
Well from my experience I actually like lc and find it useful. I usually run a 200 treadware tire with decent grip. When I use lc I try not press the pedal to the floor. I match the throttle with Rev a lil over so lc is active. Next I feather the clutch out and give throttle as needed depending on current set up. Then use nls from first to second exactly at 6k rpm therefore holding boost with maximum performance.
Hope this helps it works for me.
Old Dec 31, 2010 | 05:27 AM
Geo_SS's Avatar
same here ^^
Old Dec 31, 2010 | 08:38 AM
Cobalt_Daddy's Avatar
used it a few times... too hard on my car... i'll never use it again... my tires barely broke loose... so where was the power going? hopefully spinning my clutch and not eating the transmission lol
Old Dec 31, 2010 | 01:03 PM
Sounds good, I can never get that NLS from 1-2. Comes up to quickly
Old Dec 31, 2010 | 01:12 PM
srry i meant slip but you gotta be careful making sure you don't burn it but like everyone else is saying once you are tuned its totally different the car is just tricky to launch but practice makes perfect
like when i first went to the track after getting tuned i was actually slower than stock for a few runs but the traps were amazing just the fact i stood at the line b/c i was spinning
Old Dec 31, 2010 | 01:23 PM
Yeah I hear you, when I tried LC I just let the clutch out fast but I didnt side step it.
Old Dec 31, 2010 | 01:26 PM
yeah when i just drop i just sit there when i slip its gets a little better
i got my fastest time by launching with the tune of and turning it one when i hit like 35-40
Old Dec 31, 2010 | 01:28 PM
Hmmm well it makes sense cuz your restricting the power the wheels are actually seeing. I just have a fear of burning a clutch, she it my daily driver!
Old Dec 31, 2010 | 01:43 PM
my ss is my daily too.... the stock clutch is can take a beating even when practicing launching i doubt you are gonna burn it out its not like you keeping your foot on the clutch the entire time
Old Dec 31, 2010 | 01:53 PM
Yeah Idk I think for now ill stick to LC or if im feelin froggy I manual launch it
Old Dec 31, 2010 | 02:00 PM
i actually put the car in LC mode but only only gave enough gas to keep the revs at 2500 i only do the full when i wanna have fun and spin all crazy lol
Old Jan 2, 2011 | 03:31 AM
Stamina's Avatar
This totally defeats the purpose of Launch Control though. You're doing a manual launch if you do it as you describe here.
Old Jan 2, 2011 | 03:39 AM
of course i know that.......the car isn't controlling the launch i am....... i just like hitting the button twice thats all its something about seeing competitive mode then launch control lol haha
Old Jan 2, 2011 | 05:02 AM
alerosaint's Avatar
I agree with most of you guy the launch control is set to high.....roasted all my lil poor tires
RaginChopsuey
Oct 27, 2015 01:27 PM
ColonelMustard
North Pacific
Sep 29, 2015 03:02 PM
Extremespeed
Sep 29, 2015 04:34 AM
Coballin13
Sep 25, 2015 08:43 AM
