a legit website to buy 3-5mm wheel spacers from
Old Dec 13, 2011 | 10:55 PM
09TcSedan's Avatar
ive googled it.searched it on this forum and still havent came across anyone who has said anything about a legit website to get wheel spacers from.
members on here had mentioned either are old and out dated or bring me to a spacer but its for the wrong car.
i have IRL wheels with winter tires waiting in my garage for my SS/TC.
i know i either need a 3mm or 5mm to run safely.
anyone else done this and can chime in,please.
i found some on jegs but i feel like they are not the correct ones.
any help would be effin awesome lol
drumrush's Avatar
crateenginedepot.com
Old Dec 13, 2011 | 10:58 PM
drumrush's Avatar
5mm Wheel Spacer WS5 - Crate Engine Depot
Old Dec 13, 2011 | 11:00 PM
09TcSedan's Avatar
holyyy shittttt. i didnt even think about CED. thank you.
Old Dec 15, 2011 | 02:26 AM
silverSS08's Avatar
What about a 3mm?
Old Dec 15, 2011 | 02:38 AM
HB_SS/TC's Avatar
You can get custom hub and wheel centric spacers here
Wheel Adapters, Wheel Spacers, Hub Rings, and much more! | Motorsport Technology
I had 3mm spacers ordered from them before
Old Dec 15, 2011 | 02:42 AM
EXsoccer1921's Avatar
i have 12mm hub/wheel centric spacers from motorsport tech. quality is second to none
Old Dec 15, 2011 | 07:59 AM
09TcSedan's Avatar
i ended up ordering the 5mm ones through tom @ CED. should be arriving tomorrow
Old Dec 15, 2011 | 03:54 PM
just make sure you get the wheel centered properly while using those spacers.
Old Dec 15, 2011 | 05:29 PM
09TcSedan's Avatar
def will. i might run these spacers temporarily and check into hubcentric adapters in the mean time.
i live in MN and its mid december and we dont have any snow!!! im a snowmobiler so snow dont bother me but im wondering if i should wait to throw my snow tires/wheels on
Old Dec 15, 2011 | 09:39 PM
Powell Race Parts's Avatar
u folks dont understand. the 5 mm spacer remains hub centric thats the whole point. If you need 3 mm that is possible we make them for CED and can do a set for you.
its when you use a spacer more than 5 mm you have to make a big jump in width, so that there is enough metal to make it hub centric inside and outside, and you then need the GMPP much longer studs, which CED have available. ARP dont make long enough ones, and making wheel studs is not a cheap process, and the folks who make them in volume wont do it in lots less than a 1000 studs. I have made longer custom studs and have made 1.5 inch spacers; if you need longer studs, which i dont believe u do, go with the GMPP ones....
Old Dec 15, 2011 | 10:39 PM
09TcSedan's Avatar
CED spacers will be here tomorrow.
i was pretty confused about hubcentric spacers. but i just looked up a couple different terms and now it makes since by what ^^^ you meant.
Old Dec 16, 2011 | 01:48 AM
what i was meaning was, does the lip on the stock hubs remain long enough to be able to center the wheel when running a 5mm spacer.
Old Dec 16, 2011 | 10:36 PM
09TcSedan's Avatar
did some reasearching and now i get what you mean.
i knew nothing about spacers,hubcentric and all that jazz 5 days ago.
now i get it
ineedacobaltss
Nov 7, 2015 02:25 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
dennis69
Oct 20, 2015 04:49 PM
OrangeCoba
Oct 1, 2015 10:00 PM
goaliemo
Sep 28, 2015 01:37 PM
