LNf rods
Old May 15, 2012 | 06:57 PM
ingram57's Avatar
LNf rods
How much hp and boost can stock LNf rods hold
Old May 15, 2012 | 07:13 PM
Maven's Avatar
Plenty
Old May 15, 2012 | 07:31 PM
ingram57's Avatar
Plenty like over 400 but under 500
Old May 15, 2012 | 09:02 PM
peachpuff's Avatar
Think zzp bent the stock rods in the low 500whp range, but the pistons will give up way before that.
Old May 15, 2012 | 09:05 PM
Fastgti69's Avatar
I read somewhere that it comes with forged rods.. BTW it's not necessarily HP that kills rods, it's torque. About 500wtq or so would probably be the limit I would push as far as a stock engine.
LNF-A turbocharged direct injected (redubbed Spark Ignition Direct Injection) Ecotec was introduced in the 2007 Pontiac Solstice GXP and Saturn Sky Red Line. In these applications, the engine is mounted longitudinally. Displacement is 2.0 L—1,998 cc (121.9 cu in)—with a square 86 millimetres (3.4 in) bore and stroke. Compression is 9.2:1 and maximum boost is 1.4 bar (20.0 psi), delivering 260 hp (190 kW) at 5300 rpm and 260 lbˇft (350 Nˇm) of torque from 2500 to 5250 rpm. Engine redline is at 6300 rpm and premium fuel is recommended. The sodium filled exhaust valves were based on technology developed for the Corvette V8 powertrains. The sodium fuses and becomes a liquid at idle, which improves conductivity and draws heat away from the valve face and valve guide towards the stem to be cooled by the engine oil circulating in this area. The camshaft-driven direct injection systems pressurizes the fuel to 31 bar (450 psi) at idle, and up to 155 bar (2,250 psi) at wide-open throttle. The "Gen II" block is similar to the 2.4 L and also features VVT technology. The Gen II block was developed using data from racing programs and computer simulations. The bore walls and bulkheads were strengthened with a weight increase of 1 kg (2.5 pounds). The coolant jackets were expanded to improve heat rejection, resulting in a coolant capacity increase of 0.5 liters.
In December 2008, GM released a Turbo Upgrade Kit for the LNF engine which increases horsepower to 290 hp and torque to up to 340 lb.-ft, depending on the model. The kit retails for $650 and includes remapped engine calibration and upgraded MAP sensors. The kit is covered by the cars' existing GM warranties.[3]
Unique LNF features[4] include:
a twin-scroll turbocharger
cam-driven high-pressure gasoline direct injection fuel system
dual camshaft continuously variable valve timing
sodium-filled stainless steel Inconel exhaust valves
low-friction cast aluminum pistons with oil squirters
forged steel crankshaft
forged steel connecting rods
cast stainless steel exhaust manifold
Old May 15, 2012 | 09:41 PM
09CobaltSS1's Avatar
I thought that it was pretty well established that the lnf and lsj used forged I-beam rods..
It's not nearly as strong as an H-beam rod, but it's still a pretty stout rod.
Old May 15, 2012 | 10:44 PM
Frogstofall's Avatar
I think ZZP took the stock motor to over 600 and the only reason it gave out was bc the boost controller malfunctioned and hit the motor with something like 53psi. I also remember reading somewhere that it was believed the stock bottom end was good to 700hp. I'm sure you couldn't drive for very long on anything that high but you get my point I'm sure.
Old May 15, 2012 | 11:05 PM
Matt M's Avatar
We were throwing some theories around about the bent rods in the 530whp setup from a few years ago. One of the thigs that we needed to consider was that motor came out of a rollover car that could have filled the cylinders with oil causing the bent rods before I ever installed the motor. Wheteher that was the case or not, I did take the next motor past 600 as Frogs stated. I had one over-boost and then it let go on the next pull. I'm guessing it was at its limits anyway based on other high hp lnfs that have slight rod bend when disassembled.
I would say that they are good for 500whp with a good tune as long as detonation is kept out of the picture.
Old May 16, 2012 | 12:14 AM
Maven's Avatar
Like I said .....plenty
Old May 16, 2012 | 12:21 AM
BBC21's Avatar
yeah that is plenty low 530whp on stock internals. To be honest nobody really needs to build these blocks unless you want rediculous power which is pointless unless its a DYNO QUEEN or a pure DRAG CAR. The LNF motors are very stout and that what german/ european engineering for you though
Old May 16, 2012 | 04:35 AM
*Cough* Trans *Cough*
Old May 16, 2012 | 04:47 AM
TimJim's Avatar
p sure the trans is only rated to like 400
Old May 16, 2012 | 06:59 AM
mongorat427's Avatar
Good old Saab engines
Old May 16, 2012 | 07:48 AM
ingram57's Avatar
Thanks for the input
Old May 16, 2012 | 09:12 AM
Matt M's Avatar
Yes, even our 252 turbo kits have finished off plenty of transmissions.
Old May 16, 2012 | 03:21 PM
Oh I bet. Even less took out mine.
Old May 16, 2012 | 06:32 PM
Matt M's Avatar
oh, the BNR killed it? It is mainly the torque, so I guess mid-sized turbos are going to take their toll on transmissions.
Old May 16, 2012 | 08:22 PM
Yup. Lasted two whole days. 27psi, E47, 3rd gear pull. Was still tuning too. Doah.....
Caught it while logging too.
Old May 16, 2012 | 08:24 PM
ahhhh so you aren't on the stock turbo after all??
Old May 16, 2012 | 08:40 PM
I'm not on anything at the moment.
Edit: Except for a pair of jack stands. Haha!
Old May 16, 2012 | 09:20 PM
That sorta makes a little more sense now as to how you were pushing 40lbs/min when you got tuned by James and you guys said you were on the stock turbo still..
That definitely SUCKS though man! Having to drop the tranny again especially after you just replaced the clutch not that long ago. ****, after all this you're gonna be a pro at clutch jobs and tranny swaps on balts!
Old May 16, 2012 | 09:23 PM
I WAS on stock turbo. I just got this other one two weeks ago. We weren't lying. I still need to post those logs. I forgot all about that.
Old May 17, 2012 | 12:42 AM
Fastgti69's Avatar
The tranny is the weak point. Looks like it will be inevitable when you go BT. I hope I wont have any problems with the ZFR ..
Old May 17, 2012 | 02:40 AM
Hope is good but it's not gonna help....
Old May 17, 2012 | 02:46 AM
TimJim's Avatar
what tranny would you even upgrade to once you max the stock one out?
