Looking for good brake pads
Old Dec 25, 2011 | 09:55 PM
AyrtonSenna's Avatar
Hi all,
Currently I have R1 concept premium rotors drilled/slotted with Hawk HP+ pads. The brakes squeeks like you couldn't believe. My friends know I'm coming from 3 blocks away because of the squeeks of my brakes. I have to say that these pads are great as far as braking, but I can't take such a squeek anymore. Do you guys know about the best pads out there that don't make your car squeeking in a way that every single person turns around but at the same time you have the best braking distance possible?
Thank you
Christian
Old Dec 25, 2011 | 10:03 PM
Powell Race Parts's Avatar
the best pads ! bar none! for street and track for LNF are Ferodo HP1000 the same compound on the CTS V. In other words the stock pads you used to have on your car.
Old Dec 25, 2011 | 10:31 PM
Those are the best pads to be used?
The squeek is only because of the pads or it can be from something else?
Old Dec 25, 2011 | 10:36 PM
Fastgti69's Avatar
Those are the best pads, but they will squeak too. I have hawk HPS and they do not squeak like the stock ones do. They're good for DD as well they're okay for tracking.
Old Dec 25, 2011 | 10:38 PM
My stock pads never squeeked with the stock rotors. I don't know if with the R1 rotors is different
HB_SS/TC's Avatar
Listen to this guy
Old Dec 25, 2011 | 10:49 PM
Nick (BYT) told me that the EBC red stuff are very good pads, is it true?
Old Dec 25, 2011 | 11:04 PM
donkeyballs's Avatar
I have the same rotors with hps pads with no noise.
Old Dec 25, 2011 | 11:07 PM
ssyellow's Avatar
Please listen to the above advice. Thank you.
Old Dec 25, 2011 | 11:11 PM
Mark Aubele's Avatar
We've been through this a thousand times, HPS' are not OK for track, unless your track days involve pitting after 2 or 3 laps. Get the stock pads OP. And get rid of the drilled rotors.
Thank you
Old Dec 25, 2011 | 11:14 PM
ssyellow's Avatar
Old Dec 25, 2011 | 11:25 PM
518SS/TC's Avatar
i have brand new EBC red stuff pads for sale never installed.. i paid 130$ you cn have them for $100
Old Dec 25, 2011 | 11:41 PM
Frogstofall's Avatar
EBC pads are terrible. Def go with stock pads.
Old Dec 25, 2011 | 11:53 PM
518SS/TC's Avatar
hey now i like my ebc pads.. dont hate .. and three buddys run them and i prefer them over hawk.
Old Dec 26, 2011 | 05:54 AM
That's good for you, they are still crap though compared to the stockers.
Old Dec 26, 2011 | 08:14 AM
There you go, hard to keep the truth bottled up, stock is best. I cant count the number of times I have seen cars come in with EBC pads just falling apart. U get what you pay for.\'
stock pads squealing:
#1 the pad chamfer has to be at the top of the caliper/follow the arrow on the stock pad backing plate
#2 the stock pads come with steel anti squeal shims and copper anti sieze paste
#3 clean caliper where the pads sit, install correctly with backing plate well lubed with the paste, and lightly lube the pad backing plate ends.
#4 install with new pin kit and put anti seize on the pins where they seat into the caliper.
Old Dec 26, 2011 | 12:07 PM
Fastgti69's Avatar
Have you tried them personally? Cause I have, I've tracked with the stock ferodos and with my HPS. They're fine, but not as good as sock ferodos. No, I'm not pitting after 2 or 3 laps, after maybe 6-8.
I still say, if you want something for a DD with no noise go HPS. If you want something heavy duty, the stockers are obviously the best, I never said otherwise.
Old Dec 26, 2011 | 11:04 PM
I have tracked with both the stock pads and HPS'. At BeaveRun, a track notoriously hard on brakes, lapping in the 1:09-1:11 range (time trial), the pads were fine, lap after lap. Went up to 15 minute sessions until the stock Conti's were literally falling apart even at 58 psi.
At Nelson's Ledges, a track notoriously easy on brakes, with the HPS' the car went from adequate to me almost running into the back of someone coming out of the kink at about 125 mph, literally standing up in the car with no brakes after 3 or 4 reasonably hard laps (1:19-1:21 range). These sessions were both with the car 100% stock, no tune.
The HPS' are absolutely unsafe for track use. Fine for a cheap street pad, which is why I bought them, and haven't stopped regretting it since.
Old Dec 26, 2011 | 11:42 PM
Fastgti69's Avatar
I can't say the same about the HPS pads. They're not as bad as you say they are on the track, but our tracks are different. However, I completely agree for a cheap DD with low brake dust and no noise this is the way to go.
I gotta get the stock ferodos again and see what I've been missing I guess lol..
Old Feb 23, 2012 | 12:15 PM
BIG SS TC's Avatar
so i should call gm dealer and get a stock set of pads for the ss tc are they they the hp100 u guys speak of
Old Feb 23, 2012 | 11:23 PM
Balt_and_Vette's Avatar
i called the dealer ship today in Canada looking for same pads and it was 789 front and rears.
Old Feb 24, 2012 | 02:15 AM
ssyellow's Avatar
Because you probably can't find them online, right?
Two minutes later it appears I have found them for a grand total of $249.44 + shipping. Happy hunting!
Old Feb 24, 2012 | 11:01 AM
silverSS08's Avatar
Crateenginedepot.com ftw
Old Feb 24, 2012 | 11:34 AM
ssyellow's Avatar
Winner. ^
