Lowering Springs and Camber?
Old May 5, 2011 | 10:47 PM
apicia's Avatar
If you have been following my experience, I have added some performance mods and appearance mods to my new Cobalt SS/TC. Click on my signature to check it out if she is new to you.
Pretty much done for now, except for the alignment. With the rear acting like a straight axle, camber is not an issue. The front is where I have a problem. There seems to be no camber adjustment.
I have searched the "how to guide" forum and found little dealing with the alignment. Found a few "how to install springs" threads. Is there a consensus method of getting some of that camber back? The strut bolts looks very tight, so I imagine the Ingalls front bolts don't work.
How to we align the front end after lowering the car, specifically adding a camber adjustment?
Old May 5, 2011 | 10:51 PM
slvrred-'s Avatar
there is no adjustment in the front unless you hog out the spindle and front struts with a carbide burr. WHy would you need adjustment anyway? i've got pedders and my camber is just fine
ps too lazy to read other threads, lol
Old May 5, 2011 | 10:54 PM
ls1fbody's Avatar
Haz l33t wheelz.
there is some adjustment there. untill i slammed the **** out of mine, i was always able to get the correct camber without cutting anything. That's just in case you have to, and it's oerfectly fine to do. There are indents, and obvious markings to show you where to cut.
You can buy camber bolts, that's fine, but 95% of the time you can get back into spec with just the available adjustment.
Toe is what i would worry about when lowering the front.
Old May 5, 2011 | 11:02 PM
BlackARCA06's Avatar
Yea I have some negative camber after lowering mine in the front, im waiting for the springs to settle before the alignment. Will the negative camber eat my tires?
Old May 5, 2011 | 11:05 PM
slvrred-'s Avatar
only very slightly, toe is your MAJOR tire wearing angle
Old May 5, 2011 | 11:11 PM
bbrewbaker's Avatar
The camber won't wear them that quick.
This is my sisters 3. You can see the negative camber in the back because of being lowered and us not changing the camber links.
The tires don't show any unusual wear on the inside.
Old May 6, 2011 | 01:09 AM
Tomtwtwtw's Avatar
Just curious how lowering the front would affect the toe angle? It doesn't appear to when looking at the suspension, but definitely correct me if I'm wrong. As for camber, it will wear the inner edge of your tire a little quicker, but that negative camber will actually come in useful whenever you turn the steering wheel.
Old May 6, 2011 | 05:42 PM
apicia's Avatar
Where are the indents and obvious markings? The strut tower? The control arm? Where may I ask?
Old May 6, 2011 | 05:47 PM
ls1fbody's Avatar
Haz l33t wheelz.
where it bolts to the knuckle. It's either the top bolt hole, or the bottom. I can't remember, but there is a stamped depression there.
Old May 6, 2011 | 08:39 PM
C_A_D88's Avatar
noob question, what is toe?
Old May 6, 2011 | 09:13 PM
brainchasm's Avatar
Old May 6, 2011 | 09:44 PM
ls1fbody's Avatar
Haz l33t wheelz.
Imagine your car is pigeon toe'd
Old May 6, 2011 | 10:17 PM
apicia's Avatar
It is a condition related to camels...
Old May 6, 2011 | 10:22 PM
C_A_D88's Avatar
Gotcha
bigdeertz
Nov 17, 2016 09:41 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
dennis69
Oct 20, 2015 04:49 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
