Mods you DIDN'T like...
GMS1 on my brothers car. Worst thing ever.
As for mine, by far the stage 2 rotated mounts. I wasnt getting wheel hop on the street, i rarely track it(havent since ive owned this one in 2 months) and it just vibrates to hell with the a/c on. A/C off she is smooth as butter if its on it just makes my sunroof rattle like all hell.
The only mod I have slightly regretted is the K&N intake. It's a great product, I just get tired of hearing the blowoff ALL of the time. Sometimes I miss being able to drive quietly down the road.
anyone who's REALLY taken the time to look at it can see it for themself...
PM me some details if you want, i can easily loosen and redo them all without issue.
if I was to sit down and count every "chip" (but if bug cause the paint to pop off is it still called a chip?) - I'd put money on it right now, that I'm WAYYY past a hundred...
most are a fraction of a millimeter in size... but probably about a dozen are around 3mm...
but enough about the mod I'm mod I didn't know to install...
But seriously, why all the hate on GMS1? ~ from everything Ive read, it's all about the install ~ 909% of which would have been prevented if THESE were used on install
I mean, the tune itself isn't the culprit - it's either the splicing into the wire (and limited space to make a proper connection), or the lower map leaking (because of only one screw holding in place what used to use two)...
Seriously though, the paint on our cars is not great. But I bet if you look around your neighbourhood a lot of cars have paint chips and/or cracked windshields. At least thats what I recall from my travels in Wild Rose Country.
Your right, the GMS1 tune is not the problem, it's the install. I've only had one problem so far (No Data Available message on RPD) = loose connection on the lower sensor.
Overall I'm quite happy with my Tune. But if I knew about all the complaints before I got GSM1 installed - I would have bought those adaptors for sure!
GMTU
TTR rear sway
Poly mounts
Hurst STS
MES exhaust
Sportlines
Gen I projectors for light output
Gen II's for overall non fitment
Depo non OEM certed headlights for basic nonfitment
TTR rear sway
Poly mounts
Hurst STS
MES exhaust
Sportlines
No, I like my carbon hood and trunk, my pedders, my PRS rear bar, PRS leading and trailing bushings, my retros, TWM base bushings, interceptor with custom bezel, Ultraleggeras with star specs, Hahn catback with the muffler replaced with a dynomax VT muffler, my werkes street intercooler with anti heat soak coating, 2871R swap, TiAL Q, Synapse turbo manifold, PRS 2-pc floating front rotors, armrest
, damplified trunk, powergrid end links, steering rack spacers, PRS stage II rotated mounts
Live and learn what works for you and what doesn't.
Clean your lights with soap and water.
Prep with Acohol
Spray 3 - 4 thin coats from 6 inches
Dry in "DUST FREE AREA" not your garage!!!!
Clear coat 4 coats.
They never dull and always stay nice!!!!
AND.......dont go overboard. BLACK AS NIGHT is NOT THAT COOL!!!
Also, is the Synapse manifold really worth any noticeable gain?
Thank you. I'm so sick of hearing the VHT comment. It is all in the prep.
Prep with Acohol
Clear coat 4 coats.
COOL!!!
Prep with Acohol
Clear coat 4 coats.
COOL!!!
Going stage 3 from zzp right away and not saving up for my TVS build i want to do. I love stage 3 and it beats stock any day of the week just should have been patient and modded with a tvs before stage 3 lol.
