mpx
Old Mar 9, 2012 | 08:51 PM
Balt_and_Vette's Avatar
mpx
anybody ever have fitment issues with the mpx downpipe and exhaust? I had to heat up my down pipe at the bend and bend it toward the ground so my cat back wouldnt hit the heat shielda and gas tank. Also the muffler isn't all that centered and goes a little left of being centered.
Old Mar 9, 2012 | 08:53 PM
it also seems to make my car shake and vibrate a bit and also i couldn't make the o2 bung extender work because it didn't have room to go in.
Old Mar 9, 2012 | 09:16 PM
BPacak's Avatar
Vtec Rep
you can bend the heat shield away from the piping its not gonna hurt anything, but my exhaust is fine but i have a zzp dp
Old Mar 9, 2012 | 09:32 PM
SSlobalt's Avatar
If your car hasn't been in an accident, I'd say you have a bad pipe.
Old Mar 9, 2012 | 11:23 PM
Boosted4's Avatar
When I first installed my ZZP downpipe when my car was brand new with 2k ish miles on it, I had to bend the factory heat shield a little bit to prevent the downpipe from hitting. I agree with the others about if you have to bend the downpipe itself at all, I'd say you have a bad downpipe. The pipe itself should require no bending whatsoever.
Old Mar 9, 2012 | 11:54 PM
well i already did it and it is stainless so no harm done. just pissed me off. i still cant get the o2 extension in which is a big **** off because i went for a drive and my cel came on. I thought it wouldn't because it's a mpx downpipe with cat and is angled as well but it might as well seeing how everything else was fucked.
Old Mar 10, 2012 | 09:45 AM
Kennylr's Avatar
I have the mpx catless and it went right in with no problems from the down pipe just i had messed up the threads on the bolts in the O2 housing so i replaced them with ones from Home Depot.
Old Mar 10, 2012 | 11:50 PM
i dont get why my cel is still on though. It has a cat, angled o2 bung, and I just put the defouler in and reset by unhooking the battery and it came on as soon as I turned it off and on again.
Im thinking I messed the o2 up by twisting the wires too much.
Last edited by Balt_and_Vette; Mar 10, 2012 at 11:50 PM. Reason: Automerged Doublepost
Old Mar 10, 2012 | 11:56 PM
SSlobalt's Avatar
Very common error. It's better to unplug the O2 sensor and remove it with the pipe, then install it in the new pipe before installing the new pipe in the car. Too late for that advice, though.
Old Mar 11, 2012 | 01:15 AM
soundjunky's Avatar
you had to bend your head pipe?
wow, that's screwed up.
I have their stuff ~ IMHO it's the best out there...
Bending your head pipe would move the catback connection point in relation to the rest of hte car ~ and would probably shift the exhaust some...
If I would have had any problems I would have contacted MPx before modifying anything.
Old Mar 12, 2012 | 05:39 PM
ohh well it's already done and it sits nice now. It was my o2 by the way. I just put a new one in and reset the codes and it's gone.
Modernceo
Nov 9, 2007 11:50 AM
Modernceo
Modern Performance
53
Oct 14, 2006 04:46 PM
Modernceo
Modern Performance
Oct 11, 2005 09:30 PM
Modernceo
Modern Performance
May 8, 2005 06:53 PM
