Muffler Delete = Teh Sex
Old Apr 16, 2009 | 07:44 PM
wantedSS/TC's Avatar
Well I picked up my SS/TC and no more than a week and 500 miles later I removed the muffler. I wanted to do it on my old cobalt, but the damn thing was totaled before I could do that.
I must say, with the muffler delete, the car sounds GREAT! It has a nice throaty sound and sounds good as well at WOT. The shop charged me $90, but it was the cheapest and most reputable shop in my area. For a cheap mod that sounds great until you get a full exhaust, I'd recommend it to ANYONE!
Cheers.
Old Apr 16, 2009 | 10:10 PM
09SS's Avatar
I would have to agree that it sounds good. I got mine done this past Tuesday and I am very happy with it.
Old Apr 16, 2009 | 10:17 PM
ericgt79's Avatar
now all you need is a 3" catless dp and feel the airflow OMG.
Old Apr 16, 2009 | 10:19 PM
yellowltcoupe22's Avatar
no sound clips?? what the hell man.. cant post stuff like that around here without pics, vids, or sound clips.. lol
Old Apr 16, 2009 | 10:36 PM
Gestapo007's Avatar
got it as well for $100 cause i had to buy the new tip. but heres my soundclip
http://www.youtube.com/watch?v=3plZ71w4I8M
Old Apr 16, 2009 | 10:51 PM
this will be my first mod since im bout to be gettin a sstc this comin week..
Old Apr 16, 2009 | 10:54 PM
Haha, yeah sorry man. I just got it done tonight. Took all of 40 minutes to complete. I waited there in the lobby while they did it.
It's suggested as many have said. While the car was on the lift I looks at the downpipe to see how the install was going to look once I purchase one. Doesn't look all that bad honestly.
Old Apr 17, 2009 | 04:14 PM
Black_Turbo_SS's Avatar
down pipe isnt too bad except for the bolt that on top of the flange that conects to the muffler. with an extension its not too bad. still a pain tho lol
Old Apr 20, 2009 | 08:42 AM
drewbroo's Avatar
I got mine done for 30 bucks in tx, texas muffler shops ftw
Old Apr 20, 2009 | 10:59 AM
UltraMagnus86's Avatar
will removing the muffler hurt your car, doesnt it reduce the backpressure
Old Apr 20, 2009 | 11:25 AM
ElDude's Avatar
Cheers.
I know this has been answered before prolly, but does a muffler delete void warranty?
I don't claim to be a car tech guru, but I wanna say that the muffler is purely for emissions. I don't think the actual muffler does much, I could be newbishly wrong however.
As far as I knew, Muffler is just for the environment.
Someone clarify. I would like to know as well, and also to refer to my earlier post. Does a muffler delete void warranty. B/C I am keeping my warranty.
Old Apr 20, 2009 | 11:33 AM
Gestapo007's Avatar
I honestly dont understand exhaust all that much. All I know is that you want the exhaust to come out fast. If you use too big piping (3") and dont have enough HP the air will come out too slow causing backpressure in itself. Emissions has nothing to do with muffler or resonator but strickly cats. Mufflers and resonators should be strictly sound oriented. Some mufflers are functional and seperate the fast moving air from the slow moving air and funnel the slow air around the outside of it spinning it and blending it with the fast moving air moving through the center.
Cars are made with cats and resonators and mufflers and warrentied that they will run good for a long time. I imagine removing these parts and opening up restrictions will give you more HP but will casue more wear and tear on your engine in the long run.
Old Apr 20, 2009 | 11:35 AM
Witt's Avatar
Yes, it does reduce backpressure. That is good for the car, not bad.
Muffler is for noise regulations, nothing to do with the environment.
Old Apr 20, 2009 | 11:36 AM
Gestapo007's Avatar
Muffler delete will not void your warrenty. nothing will just straight out void your complete warrenty all together that I know of. If you tuen it i imagine you still have a suspension warrenty. Get what im saying?
Anyways your muffler delete should not cause any problems at all except **** off your neighbors and I dont believe GM techs will give a **** if you have a fart can or no muffler at all when you go in for a new belt or squeaks or something.
Old Apr 20, 2009 | 11:40 AM
tuckedls's Avatar
so if i wanted to do it myself, i would cut out the muffler, replace with some couplers and same size piping, and done correct? throw some welding in there too obviously...?
Old Apr 20, 2009 | 11:57 AM
Exactly. I don't have any welding techniques or skill so hence why I paid for mine!
Old Apr 20, 2009 | 12:04 PM
NobDaSkrilla's Avatar
Couldnt you just saw it off yourself for cheaper?
Old Apr 20, 2009 | 12:10 PM
You can do whatever you'd like to be honest. I didn't have a power saw that could cut through metal. I figured I might as well have the shop do it all so if something gets jacked up somehow, I can go back to them with my rants .
If I had a power saw, had a lift and knew how to weld, I'd do this myself. This isn't the case however, so I gotta pay to play!
Old Apr 20, 2009 | 12:16 PM
tuckedls's Avatar
i am thinking you could do it fairly easily with a jack and a sawzaw. and you could prob use some coupling to put it all back together, but i'd prob weld it because it'd be a lot safer. i can't weld, but my buddy and his dad can. so i think that's what i'll do. same as a shop would do right? anyone?
Old Apr 20, 2009 | 12:19 PM
Terminator2's Avatar
No, Cars do not need back pressure. That is an old myth that is actually true on carburated cars and trucks. Too little backpressure causes lean A/F mixture and burnt valves because of the increased flow and no way for the car to compensate by adding more fuel. Less backpressure is much better, An engine is an air pump the more air in and out the more HP. Less backpressure means faster turbo spoolup and The stock muffler is strait through BTW It flow better than the s bent part of the exhaust system. It is purely a sound mod. No hp gain from a muffler delete on these cars.
Old Apr 20, 2009 | 12:22 PM
tuckedls's Avatar
damnit
Old Apr 20, 2009 | 11:25 PM
09SS's Avatar
I completely agree with Terminator2.
You can do the muffler delete yourself but unless you bend the pipe it will come out of the bumper crooked. I got mine done for $100 as well. It was well worth it for me. The place cut the muffler off, expanded the ends, bent the pipe, welded all of it and welded 2 hangers back on the pipe to hold it up.
Old Apr 21, 2009 | 07:23 AM
burleson86's Avatar
so no muffler = ok ? no check engine light .
Old Apr 21, 2009 | 09:21 AM
tuckedls's Avatar
and if i just cut it off at the muffler, and leave it like that, will is sound funny if i don't extened out to the back? and x2 on the cel?
Old Apr 21, 2009 | 10:41 AM
No CEL. And why would you want to just cut the muffler and not extend the tip? If you're going to do something, please don't do it half-assed. You can cut the muffler yourself and then take it to a shop in which they'll charge you $50 bucks to weld on a straight pipe with your stock tip welded onto it. That's the best way to go IMO.
