My 418$ Service that fixed my rough engine!
I have had recent work done on my car to get it back running to 100% I don't wanna type what was wrong with it so here's a link to my post. https://www.cobaltss.net/forums/08-0...unning-222856/
Instead I want to talk about what my bogging above 5,500rpm was all about. I took the car in Monday to the dealer, after a expensive service bill that i thought they were going to cover it came back around n bit me in the ass. The reason for my car to run so bad was a clogged air filter!!!!!!!! Can was not get sufficient amount of air at 5-5,500 rpm and would die off consistently everytime there.
In conclusion they nailed me for a 418$ Airfilter/service bill that will happily remind me always to keep up with maintenance. Funny thing is car just broke 22,000kms and I didn't expect to have to change it that soon...so if u r having engine issues with ur car hitting a wall at roughly the same rpms as I did then please check ur air filters most likely they are dirty.
Oh and the car runs fantastic now pulls all the way to redline.
I had gm tell me I was running nitrous and swaped bigger injectors. Let's put it this way that guy no longer works for gm cause he was herassing me as I was young and the car only had over 3,000 miles as I bought it new and only went in to get my oil changed. Then they tried to charge me for a blown fuse to my passenger air bag over $100 for a cheap a$$ fuse and labor how hard is that LMAO but when ur car bogs like that it is always the least thing u would expect to be the problem. When my car had problems I just went stage 3 and more and fixed all my problems
Yea they some time looking for the issue but I went in with codes p0300 n p0304 both misfire codes
So, are the air filters getting wet when it rains, even in the stock airbox? I have the 5500RPM bog, but it's only when it's raining.
Thanks, John! Glad you got her worked out. I bet the $418 feels worth it just to get your car running right again.
patooyee
Oct 1, 2015 01:07 PM
