New oil catch can @ mpx???
Curious about this too. I wonder how costly it would be to substitute the rubber hoses with either SS or nylon braided instead of regular rubber. If anything at least for the aesthetic value.
doesn't any catch can work? just a matter on how you mount it and the proper size hoses you get from the hardware store??? I got my Greddy one on, but didn't know where to mount it so took it out and slapped a breather on. IMO $110 is a little pricey for a water-air separator
lol hilarious.
haha you'd be surprised the amount of oil I had in my intake and turbo when I installed my k&n intake with only 9k miles on my car...
when i was installing my new valve cover and catch can and BOV i saw a little bit of oil under the intake so im thinking this was a good buy...everything installed seems to be working fine no leaks on the valve cover yet. came with new gaskets and everything so seems all is well...SO FAR..still need a tune bad but Haza will be hooking that up soon so i should be running awesome in no time
I removed a bud's lower CP yesterday and when I got the pipe off OMFG!!! I saw quite a bit of oil lacing the inside of the pipe on both ends! I'm not talking minute amounts, probably close to a half ounce if I had to guess! When I took my pipes off before the winter they were bone dry so I'm still not sure whether a catch can is necessary for my car just yet.
yea you waited too long...funny thing is they just hit the shelf (site) a day or so ago and people went for them like crazy....like waiten outside in line all night for a new pair of jordans to come out
wait, so the unburned fuel for the most part coming from the outlet on the valve cover going to the intake is essential for HP? If not, I do not understand why anyone would want to blow $110 on a water/air separator. So someone on here says they are not all made the same?? Does MPX have a turbine to cyclone the air in your intake? I mean as long as it lets unburned air/fuel pass and trap oil it is a good catch can right?
Is anyone aware of the contents of the catch can? What would set a good oil catch can apart from the rest would be lots of surface area to impede the vapor flow to allow for condensation of the vapor (ie. stainless steel mesh). I know a lot of the generic catch cans are usually empty, with perhaps a baffle between the inlet and outlet.
Also, I'd like to know if anyone has had issues from the dealer about voiding the warranty when the catch can is installed (since you are altering the emissions system of the car)
http://www.modernperformance.com/cat...ea20a171ccd544
here is a link
