Next mods???
Old Oct 7, 2012 | 01:45 AM
Jbartock's Avatar
Next mods???
Looking for some input on new mods...
Currently:
ZZP Catless DP
Injen upper charge pipe
K&N SRI
OTTP Stage 2 Trans/Mounts
MPX Intercooler
Forged BPV
TWM Short Throw Shifter
Trifecta Tuned
Bigger turbo? If so what? Re-tune? Hmmmmmm Thanks for all the help in advance!
Old Oct 7, 2012 | 12:15 PM
Nfamous60's Avatar
maf relocate with lower charge pipe,exhaust, cams maybe built head depends on wut u want to spend for your next mods.
Old Oct 7, 2012 | 01:20 PM
09CobaltSS1's Avatar
Cheapest/easiest "mod" at this point for you would be to switch to e47 and get retuned. If you're looking to spend some money (depending on power goals and budget of course) I would maybe go with something like the zfr 6758 or bnr 2871. Either of those turbos with upgraded cam lobe, 5th injector and e47 you can get a solid 450whp no sweat.
You can of course always go with a bigger turbo, but unless you're looking to do a full engine/trans build I would just stick with a smaller turbo like the 2 I mentioned above.
Old Oct 7, 2012 | 07:10 PM
casionerd's Avatar
village idiot
Currently:
ZZP Catless DP
K&N SRI
MPX Intercooler
Forged BPV
Trifecta Tuned
wheels
tires
springs/coilovers
ss brake lines
sway bar
front end links
hids
upgrade stereo
etc etc
Old Oct 9, 2012 | 02:29 PM
Jbartock's Avatar
Liking these ideas for sure any recommendations for where to purchase zfr or bnr, cam, 5th injector, and is e47 a hassle or not really? hear is a 50/50 mix e85 and 93 oct. get around 400-450 whp sounds nice to me for time being wouldnt want more still my DD. Should I get new exhaust for after the downpipe or just not mess with it?
Old Oct 9, 2012 | 10:01 PM
Jbartock's Avatar
Plan on doing the e47 tune on Saturday by ccss3 Still a little nervous about the mixing of 85 and 93 but have a few stations right around me so shouldn't be an issue
Old Oct 9, 2012 | 10:44 PM
The "zfr" is just a borg warner efr6758 that ZZP took and designed an exhaust housing for that is a direct fit onto the stock manifold. The BNR2871 is basically a hybrid turbo of the stock k04 coupled with a garret 2871 compressor that is also a direct bolt on, however unlike the zfr, will require a bov. There is honestly tons of information on both turbos on here so try to search out some threads particularly in the lnf tech section and do some reading on them. Both are great options, but the EFR is a slighty bigger turbo with a little more power potential and a slightly bigger price tag.
Man, once you switch to ethanol you will never ever want to run your car on anything else. It's really not at all complicated to mix, especially once you get the hang of it. Like you said above, it's basically a 50/50 mix of e85 and 93 octane, HOWEVER, you can not (and i can not emphasize this enough) always assume that what you're getting out of the pump will always be e85. My best recommendation for you, and anyone looking to run an ethanol blend, is to invest in a fuel tester. This right here will be the best $15 you will ever spend when it comes to keeping consistant fuel mixes. Quick Fuel 36-E85 - Quick Fuel E85 Fuel Testers - Overview - SummitRacing.com
Reason I say this is because the blends from the pump change from region to region throughout the year, and even from station to station sometimes. You may one day have e85 come out of the pump, and a few days later get e75 and never know any better until your fuel trims are thrown through the roof.. lol
If you use the tester along with the bottom two calculators in this link, Miles Per Dollar Calculator, you should have no sweat maintaining a consistant blend all year round.
Old Oct 10, 2012 | 01:15 AM
Jbartock's Avatar
Look forward to the new tune! Thank you SOOOoo Much for all the help. I've been hunting the forums all day and have found Lots of info already. Including your tester haha Appreciate the link and new turbo to come... In the future though want to get my 69 camaro SS sprayed and put back together first. But E47 this saturday... absolutely! Thanks again..
bigdeertz
Nov 17, 2016 09:41 AM
chefhhr
Oct 26, 2015 10:36 PM
Builttss
Oct 4, 2015 10:21 AM
nathan112i
Sep 30, 2015 07:12 PM
dieGone
Sep 23, 2015 10:20 AM
