Non-sufficient Dyno Results Trifecta 24 psi
Old Jul 7, 2012 | 01:16 AM
tureka's Avatar
Hi all.
Just dynoed (Dynojet) today at Colvin Automotive in Austin, Tx. It was about 95 degrees outside.
The first dyno sheet shows stock vs tuned. The second dyno sheet I had spark blowback for some reason, thats why its all wack.
Stock Tune: 246 HP, 241 TQ
Trifecta 24 PSI tune: 284 Hp, 330 TQ
Any reasons why my numbers are lower than they should be? I'm sitting at a 38 hp gain from my mods/tune.
My mods are:
CIA SRI
CIA Downpipe (high flow cat)
MPX catback exhaust with muffler
ZZP top charge pipe
24 PSI trifecta Tune
Do the AFRs seem right?
recently changed the plugs, went with stock plugs gapped to 0.034, the originals were at 0.036 when I pulled them. I bought the car with the intake, downpipe, chargepipe, and tune. Never dynoed before today, rather disappointed.
Thanks for the help
Old Jul 7, 2012 | 01:22 AM
FasterIsBetter's Avatar
Is that corrected or uncorrected?
Old Jul 7, 2012 | 01:23 AM
tureka's Avatar
I don't know if thats corrected or not. The pull was made in 4th gear, which I guess is very close to a 1:1 ratio with the LSD
Old Jul 7, 2012 | 01:31 AM
EXsoccer1921's Avatar
i'm guessing so since its labeled sae.
i mean really 38/89 increase isn't that bad for just adding the tune. intake, exhaust, and one pipe isn't going to make ZOMG numbers ya know.. throw in the lower pipe and intercooler. maybe switch to e85 or run a mix of 110 and pump gas for a 100 octane mix and tune again. what fuel were you one anyways?
Old Jul 7, 2012 | 01:35 AM
tureka's Avatar
That was 93 octane. Shell V-Power.
The best I have ran on a track was a 14.0, but I know a lot of that is driver mod.
Old Jul 7, 2012 | 01:39 AM
also lsd isn't going to effect any ratio though. 3rd and 4th are pretty much even when choosing a gear to dyno in. majority go with 3rd simply because its less wheel speed. which means the dyno doesn't work as hard to slow down, and if something were to break, they'd much rather have it happen at ~115mph vs ~155mph
Old Jul 7, 2012 | 01:46 AM
cranemaster's Avatar
That seems bang on to me.. CAI and high flow cat are the only real performance mods.
catless is the real gains, and in most cases CAI does nothing? maybe im wrong though, id say stingy dyno as your tq both stock and tuned seems only slightly low..
tureka's Avatar
Well I guess Ill just get in line for an ZFR, if such a line exists. Its so hard to contact zzp now
Old Jul 7, 2012 | 02:12 AM
besides don't think of it as only 284whp. think of it as only 16whp away from 300..
Old Jul 7, 2012 | 05:04 AM
m33pm33p's Avatar
Numbers look right, throw an intercooler on there and you can go a bit more aggressive with the tune.
I hit 13.85 on a 20psi trifecta tune tonight, and im a terrible driver too
Old Jul 7, 2012 | 05:27 AM
Melvin's Avatar
I'd say the temps are hurting you quite a bit. Going by the times on the sheet you did the second pull within a minute of the first and they get pretty hot on a dyno. Especially on a 95 degree day.
Old Jul 7, 2012 | 09:02 AM
1SLOLT1's Avatar
Yea looks right I know you where looking for more. This happened to me in Florida same mods.
Old Jul 7, 2012 | 09:51 AM
TommyP's Avatar
AWD > FWD
You said it was 95* outside, there's your problem. High ambient heat kills cars, especially fi cars
Old Jul 7, 2012 | 10:39 AM
themacguy's Avatar
Great numbers for 95* and no cold soak between runs.
Old Jul 7, 2012 | 11:47 AM
tureka's Avatar
I guess thats what I get for dynoing in the Texas Summer. Would a new intercooler make a significant difference? I have been looking at the shorter version of the ZZP one for a while. I thought the temps were about the same, just better endcaps.
Old Jul 7, 2012 | 12:30 PM
Kahless's Avatar
same day? torque increase is nice tho. its been humid as hell lately too
Old Jul 7, 2012 | 12:35 PM
If its corrected though the temps wouldn't affect that reading. Thats what the correction is for.
Old Jul 7, 2012 | 01:02 PM
SSlobalt's Avatar
Numbers sound right to me. OP, did you have your ESC turned off?
Old Jul 7, 2012 | 01:31 PM
Marca34's Avatar
312hp & 398TQ at 24psi HPTuned. 95*
Old Jul 7, 2012 | 01:57 PM
1SLOLT1's Avatar
Yea Ive seen some post where the ambient temps were about the same, and yes the end caps are the problem on the stocker.
I have the full size ZZP intercooler Im lowered and havent had any issues!! Go full size!
Old Jul 7, 2012 | 02:00 PM
tureka's Avatar
What about the whole spark blowback? Should I go with 1 step colder plugs or regap the plugs?
Old Jul 7, 2012 | 02:05 PM
1SLOLT1's Avatar
I have full bolt ons and you seen me run at the track Im still on stock plugs with no spark blow out so youll be fine.
how much did they charge you for the Dyno?
Old Jul 7, 2012 | 03:12 PM
SSlobalt's Avatar
If you're not on an E-mix, I can't accept these numbers.
Old Jul 7, 2012 | 07:49 PM
I just did the conversion, and holy crap thats some hot ass weather!
Its usually 70-75 here all summer.. and dryer than a ma-faka, and low elevation. My turbo loves me =)
Old Jul 7, 2012 | 08:55 PM
SSlobalt's Avatar
It's hotter than the 3rd level of Hell, in Austin. 102 today with horrible humidity.
