Is this normal?
Old Sep 12, 2009 | 01:08 PM
markerSS's Avatar
Is this normal?
I got a 09 TC with about 4k miles on it. This has happened 2 or 3 times. When I drive home from work in the rain and get home and park. The next morning when I back out of the parking lot there is a loud noise comming from the rear of the car. It goes awey withing ten feet of backing up. I'm not sure if its the rear breaks sticking or what. It only does this after driving in the rain and the car sits over night. Any insight would be helpfull.
Old Sep 12, 2009 | 01:12 PM
krispy's Avatar
corrosion on the rotors that forms quickly and gets worn off even faster
Old Sep 12, 2009 | 01:16 PM
Sweetsandman's Avatar
Yeah that's pretty normal stuff..it'll sound like a light grinding I'm assuming? Take a look at how rusty your rotors are the morning after it rains...mine get rusted over pretty quickly but coming to a stop once or twice gets rid of it all.
Old Sep 12, 2009 | 01:19 PM
markerSS's Avatar
Thats what i figured. It's a really loud ugly noise. Oh, and it does it without me pushing on the break. forgot to add that tidbit.
Old Sep 12, 2009 | 01:23 PM
Yeah the rust bubble and stuff build up pretty quick and pretty thick at that...and with how close the pads run to the calipers on these things...it'll do that. Try this:
With your car off...pull the ebrake up as hard as you can and hold it there, Then pump the brake pedal about 7 or 8 times, then put the ebrake all the way down and repeat the process once more. The E-brakes on these things are awful and it usually tightens everything up and resets it all when you do that. Mine used to not hold at all and was very loose. This method solved that problem and my ebrake is pretty much fully engaged by 3 clicks now and I rarely get that grinding noise you speak of anymore.
Old Sep 12, 2009 | 01:24 PM
markerSS's Avatar
er, brakes rather just got out of bed
Old Sep 12, 2009 | 01:26 PM
sport08's Avatar
yeh my 2.4 also made this noise u speak of.
markerSS's Avatar
Thanks man, I will give that a try. Also I'm thinking about looking at the lube points.
Old Sep 12, 2009 | 01:45 PM
Hmm..I didn't even think to check those...Wouldn't surprise me one bit if they had no grease on the whatsoever
Old Sep 12, 2009 | 02:01 PM
markerSS's Avatar
Yeah, it will have to wait, but ill check them next weekend. I will update what I find.
Old Sep 12, 2009 | 04:12 PM
rukkee's Avatar
It's the rotor's rusting over night......My old SS/SC did it and the TC is just as bad. And my cars sit in the garage and it doesn't help it/
Solaris99
28
Mar 15, 2017 01:22 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
roth
Sep 26, 2015 12:16 PM
