Nothing but problems
i check every connection on the wheel hub disconnected the wheel hub sensors after putting in new wheel studs in and the traction control and abs light came on i left the battery cables off for a few hours thinking that was the problem and its not i checked the fuses im hopping i didnt break the wheel speed sensor cause i dont know which side its on and i blew a map sensor on my lower cold side pipe i have a code P0107 and on the dealer not they wont fix the wheel hub sensor sometimes i just wanna drop it off in the city with the keys in the car and let someone have it .. when it comes to car problems after the last problems i had with this car
check the wires at the bend by the control arm where they go to the sensor. grab onto a chunk of the wire and give it a firm pull. Many times ive seen the wires break inside the insulation.
