Odd sound coming from turbo
Old 05-30-2018, 12:28 AM
That SS Guy's Avatar
Like the title says, when I accelerate and get above 3k rpm the turbo starts to make this weird sound , sounds like if you taped paper to the compressor fins and spun it really really fast, tryed posting a video but no can do and Im nkt sure what it is.
Old 05-30-2018, 02:22 AM
Sharkey's Avatar
pull the intake off and check the shaft play, the fins are likely hitting the housing.
Old 05-30-2018, 07:31 AM
There is no shaft play at all, that was the first thing i checked, and fins look to be in good shape no shaft play and compresspr wheel spins freely/no resistance.
Old 05-30-2018, 11:18 AM
cluelessk's Avatar
How about shaft play in and out?
Old 05-30-2018, 01:02 PM
I tried moving it in and out but nothing, it feels very sturdy. I'm not sure but it may have been replaced before i bought it, it make boost fine about 13-15 psi , wasnt sure if it was the wastegate or bypass valve maybe failing.
Old 05-30-2018, 02:58 PM
cluelessk's Avatar
I get a weird pulsing type noise under boost until the car has been up to temp for a while.
I'd check wastegate next.
Old 05-30-2018, 04:41 PM
is there a method to checking this build in wastegate as opposed to checking an external one?.
Old 05-30-2018, 07:09 PM
Solaris99's Avatar
Does it make the sound after it is warmed up? The wastegate plungers on these end up loosening a little and rattle when cold. If that's what it is, it should go away when warm.
Old 05-30-2018, 09:07 PM
havent checked the wastegate yet, but i was listening to it on the way to work today and and the serpentine belt has some small cracks in it and could be slipping some...or alot tensior pulley is eother black from tje fsctory or black from the belt slipping on it, gonna try and replace the belt and see where that gets me, ill check the wastegate while im at it also.
Old 06-02-2018, 12:16 AM
nope changing belt amd tensior didnt work either.
Old 06-02-2018, 06:59 AM
Solaris99's Avatar
So it makes the sound after the engine has been well warmed up? Like after 15-20 minutes of driving.
Old 06-02-2018, 08:34 AM
yes, I just dont know, it makes boost and holds it redline fine , belt and tensior are new, idler pulley has 7k miles on it .
Old 06-03-2018, 01:58 AM
blackbird's Avatar
Stock air box? My car has mostly been in storage but it was making a similar type noise to what you were describing last I was driving it a bit. After-the-fact I recalled that there's a piece of foam that mates the lower snorkel to the lower air box assembly. Possible it could have came loose and is sucking and flapping in the lower intake tract.
Another possible area that might cause something similar would be the compressor by-pass valve (i.e. "blow-off" valve) if the diaphragm isn't sealing correctly. That or maybe something like the PCV valve is flapping on it's seat. Unfortunately sounds are difficult to diagnose over the internet, even if you were able to make a video or audio recording.
Old 06-03-2018, 02:00 PM
I did consider the intake could be an issue, I'm actually looking for either a CAI or short ram inake. the tube was serperated from the air box so i used some flex seal tape to close the gap.....but despite my best efforts, it's still giving me ****.
krome_dome
05-06-2015 03:30 PM
GreenySC2
05-10-2014 10:10 AM
CobaltKatsu
Forced Induction
08-11-2010 03:53 PM
SSchargedSS
04-27-2009 08:08 AM
Hasenbonkers
04-24-2008 12:54 PM
Quick Reply: Odd sound coming from turbo
