shaft play
Old May 9, 2014 | 04:48 AM
GreenySC2's Avatar
shaft play
So my car has been acting or rather feeling a bit off lately so I'm going to check shaft play Saturday, but what is "acceptable" in that aspect?
I'm kinda on the fence about what I'd like the out come to be... it may put a trip on hold if it's there but in turn new turbo so yeah..
Old May 9, 2014 | 05:33 AM
REDi DEViSTATOR's Avatar
A little side to side is normal. The way I've always seen it, if you can spin the wheel freely while "wiggling" it and it doesn't hit the compressor housing/stop spinning you're golden. Do a push/pull test on the inducer while spinning. Under load that's the direction the wheel will have pressure and could possibly be hanging up.
Old May 9, 2014 | 08:12 AM
redcobalt07's Avatar
Shaft play is definitely not acceptable in public.
Old May 9, 2014 | 09:17 AM
tomj77's Avatar
If ur turbo is making the proper amount of boost and not making noise , I'd doubt that's ur issue. What exactly does feeling off feel like? What's it doing or not doing?
Old May 9, 2014 | 10:12 AM
QuickSilver_SS's Avatar
Lol
Old May 9, 2014 | 10:42 AM
GreenySC2's Avatar
Sure it is!
Anyways it just makes a weird noise under boost, it's still hitting the right psi and all that jazz it just feels a bit lethargic here and there... it's spotty
Old May 9, 2014 | 11:19 AM
tomj77's Avatar
Could be the turbo then.
Old May 9, 2014 | 11:25 AM
a little bit of shaft play is alright but if it blows up things will get messy
Old May 9, 2014 | 11:39 AM
user 72239's Avatar
There should be little shaft play. Some side to side is normal. Check to see if its been hitting the housing. there should be no scratch marks. Also check the turbine blades to see if something has hit it.
Old May 9, 2014 | 12:09 PM
jvirginillo's Avatar
Posts about Shaft Play belong in the Dungeon......Moderators?
Old May 9, 2014 | 03:46 PM
GreenySC2's Avatar
That I can do, will just checking from the intake side be good or should I ready myself to remove the whole thing?
Old May 10, 2014 | 10:10 AM
user 72239's Avatar
Nah just the intake side should be fine. if anything is bending the exhaust side you have some serious other problems
Solaris99
28
Mar 15, 2017 01:22 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
justinchinn
Oct 2, 2015 12:18 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
