lnf stuttering bad with accelration
Old Apr 30, 2014 | 07:27 PM
coolscott18's Avatar
hi my cobalt is running really bad when i accelrate it stutters alot when i give it say half throttle, i feel like the boost isnt climbling like it should be at lightish throttle. but its fine if i downshift from third to second and floor it no problems until i hit third gear then it will stutter. i have hahn catless downpipe, zzp canned tune 22 lbs of boost, gmsi map sensors(tuned) injen cold air intake( tuned) ingen upper charge piping. car idles fine and can be driven normally with no trouble. the list of codes i got are
P0089
Fuel Pressure Regulator Performance
ECM
P0627
Fuel Pump Relay Control Circuit
ECM
P0300
Engine Misfire Detected
P0301
Cylinder 1 Misfire Detected
P0302
Cylinder 2 Misfire Detected
P0451
Fuel Tank Pressure (FTP) Sensor Performance
ECM
i have cleaned maf sensor and replaced it.
i have got the fuel system cleaned by GM valves throttlebody etc
if anybody can help me out id very much appreciate it!
Old Apr 30, 2014 | 07:28 PM
i have replaced all coil packs and spark plugs also
Old Apr 30, 2014 | 07:36 PM
N1ckateen's Avatar
I'd start with the canned tune. zzp isn't bad at tuning, but every car is different so a canned tune is only "so safe". Look into finding someone that can do a custom tune for you. Might also do a compression test just to make sure there's no internal damage. sounds like you already did plugs and coils.
Old Apr 30, 2014 | 07:39 PM
both cylinders misfired 22 times when this happens was logged form gm scanner
this occured before the tune, i thought it would have fixed it lol
Last edited by coolscott18; Apr 30, 2014 at 07:39 PM. Reason: Automerged Doublepost
Old Apr 30, 2014 | 07:43 PM
N1ckateen's Avatar
I would still definitely recommend getting a custom tune. not to mention during the custom tuning process (datalogging) they can monitor all sorts of things going on.
Old Apr 30, 2014 | 07:46 PM
Shanedude's Avatar
Never tune your car if if has issues. Fix it first.
Old Apr 30, 2014 | 07:47 PM
no doubt i will eventually know one around me tunes. it feels like its not getting much fuel idk its really weird
Old Apr 30, 2014 | 07:51 PM
sundevil07's Avatar
Sounds like the sock in your fuel tank is gummed up, check for any signs of fuel leakage at the hpfp. Not an easily diagnosable issue over the net. I can tell you that suggesting a custom tune to fix a mechanical issue is a good way to **** off your tuner.
Old Apr 30, 2014 | 07:54 PM
oh yea forgot to mention car is running really rich and smells like gass, and it backfires so much its not normal. it back fires at low rpms everytime, even switching gears
Old May 4, 2014 | 11:11 PM
could it be a clogged fuel filter??
Old May 10, 2014 | 06:04 PM
SSlobalt's Avatar
There isn't one on these cars. Gunky valves or cracked piston.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Oct 13, 2015 09:32 PM
patooyee
Oct 1, 2015 01:07 PM
Iceberg
Sep 29, 2015 12:33 PM
